I calibration the toner after appear the line in print
  • Office Equip... Master
  • 6,161 Answers
Replace the image unit causing the linre if red then magenta if blue cyan
Posted on Jan 22, 2016
Hi dear experts ,hp color laser printer cp1215 is out of calibrate.What can I do to solve this problem ? Thanks .
  1. to recalibrate: first open Toolbox.
    • For Windows XP:
    • Click Start (), click All Programs, click HP, click your product, and then click HP Color LaserJet CP1210 Series Toolbox.
    • OR in Windows Vista:
    • Click the Windows icon (), click All Programs, click HP, click your product, and then click HP Color LaserJet CP1210 Series Toolbox.
  2. Click the Device Settings folder, and then click the Print Quality page.
  3. Under Print Quality, click Calibrate next to Calibrate Now.
  4. Click OK when the 'Your request has been sent to the device' message appears on the computer. The calibration process begins.
    NOTE: Calibration might take 2 to 3 minutes. Do not turn the product off during calibration.
  5. When calibration ends, try printing again. If the issue is resolved, stop troubleshooting.
    • If you are still experiencing print quality issues, repeat steps 1 through 5 in this solution. You can recalibrate the printer as many as 3 times.
Oct 02, 2017 | Laser Office Equipment & Supplies
How can i fix the dark line in ir 3300 appearing on paper when printing?
If you have pulled the paper while printing, you might need to re-calibrate the drum. Go to your printer settings and re-calibrate it.
Aug 04, 2014 | Canon IR 3300 Digital Copier
HP M375 prints out of alignment
Are you using 3rd party consumables?
even if you are not I would recommend you replace all 4 imaging units ( toners) and allow the machine to perform the calibrations before using,
also I would clean the image belt calibration sensors ( located along top edge of ITB ) as they often get coated with toner particles,
also - is there a grinding noise - this could indicate a poor fuser- which if the vibrations are strong enough will definatley alter the printed image
p.s. 3rd party toners arent cheaper, the damage they do is unseen by the user until its too late by which point all the savings you made and more will be needed to repair/replace.
Mar 05, 2014 | HP LaserJet Pro 300 color MFP M375 MFC /...
Toshiba 3511 color print problems
Hope it's not the calibration. This could happen due to transfer belt timing problem. There are sensors and reflectors inside the transfer belt assembly. They may be dirty. Clean them or replace the transfer belt if required.
Oct 03, 2012 | Toshiba E-Studio 3511 Color Copier
Lines on paper produced by lines on drums new
The link below will provide you with all the necessary information to fix issues related to the HP Laserjet 2420 Printer
HP Laserjet Troubleshooting
Also, try the steps below.
1. Turn the printer off, and turn it on again.
2. Force a calibration by selecting CALIBRATE NOW from the Print Quality Menu.
1. Press example (Select) to enter the MENUS.
2. Press example (Down Arrow) to highlight CONFIGURE DEVICE.
3. Press example (Select) to select CONFIGURE DEVICE.
4. Press example (Down Arrow) to highlight PRINT QUALITY.
5. Press example (Select) to select PRINT QUALITY.
6. Press example (Down Arrow) to highlight CALIBRATE NOW.
7. Press example (Select) to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
3. Perform a cold reset on the printer.
1. Turn the printer on.
2. Watch the control panel.
3. When the memory starts counting, press and hold the green example (Select) button.
4. Continue holding the green example (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
6. Press example (Down Arrow) button once. The control panel will display COLD RESET.
7. Press example (Select). The printer will perform a cold reset and then continue its power-on sequence.
If this issue persists, contact an HP-authorized service or support provider. ( 1-800-474-6836 )
If the Toner is newly purchased and it is because of faulty toner, HP will replace it for no charges.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 05, 2011 | HP LaserJet 2420 Printer
Toner lines randomly appearing throughout copies
Clean the ADF slip glass..  try printing a counter sheet   USER TOOLS /COUNTER/ print if the lines do not appear on this print the problem will be with the optics.. good luck
Apr 22, 2009 | Gestetner Copier
RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Oct 15, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Spots/Lines on the prints
Take out the drum cartridge (piece with the long green arm) and look down inside the printer for any toner that may be leaking on your pages.
So I understand correctly, you were seeing different color toner on the cyan and yellow rollers?. If so gently clean that side of the roller off. Rotate the white gear on the right side of the toner cartridge back towards you and see if the correct color comes back on the roller. If you were seeing grooves on the roller then they will have to be replaced.
Put the toner cartridges back in and run color calibration.
Press menu/select. Right arrow key until you get to engine. Press select. Left arrow key until you get to service.
Press select. Right arrow key until you get to color calibration.
Press select.
Any other information would be helpful.
Jul 17, 2008 | Konica Minolta magicolor 2430 DL Laser...
32 people viewed this question
jasbo
jasbo
