Question about Locks & Locksmithing
Where the battery and how do I reset this safe SBW3500
Can't open safe!
If it still doesn't open after you replace the batteries then it is probably do to it being Jamed. I'd suggest tapping it with a bit of force but if it still doesn't open to go and see if someone can fix it.
Aug 12, 2016 | Sentry Safe Fire-Safe Home/Office Safe
Battery light yellow, proceed light green but safe wont open.
it need new battery or you need to open it with your back up key and reset your combnon to the safe if that don't work the safe is broke
Jun 05, 2016 | Sentry Fireproof Safe
The safe i have is locked with the door open. How do i reset the safe to close the door.
Remove the batteries end leave it for 10mins or so..then replace batteries and set a new combination on the lock.
Feb 24, 2015 | Sentry FIRE-SAFE Combination Safe DS3431,...
Hi, I used a code for my safe but have been using the key as batteries ran low... i have now replaced the batteries but the code doesn't work... do i have to reset the code, if so how ?
Safe locks usually retain the code, but if the batteries are low for a long time, the lock could have reset to a default factory code. If there is a reset button inside the safe, push that and enter a new code. Instructions vary depending on brand and model.
Sep 04, 2014 | Locks & Locksmithing
Change code sentry
Did you try to tale out batteries for a minute, I hope it`s gonna reset the code
http://www.ehow.com/how_7371620_replace-batteries-sentry-safe.html
Dec 17, 2013 | Sentry Fireproof Safe
No override key to open the safe and need to change battery
is there a reset button in the sentry safe X055 that i could use to reset the password
Nov 15, 2012 | Safe International Sentrysafe X055...
Start over with money
Here is a link to the PDF Instruction Manual. I have also copied the instructions for resting the amount to zero:
To Reset Account To Zero:
Turn on the ATM Safe by inserting your ATM card into the slot and entering your PIN code.
• Press and hold the 1, 2, and 3 keys (Fig 8).
• The display will read, "Reset to zero?"
• Release the 1, 2, and 3 keys and then press the "e" key.
If the electronic functions of ATM Safe stops working, open the battery door
(see instructions "To Install Batteries") and locate the RESET button above the batteries.
Press once to reset. Note: Account balance will not reset to zero.
Jan 25, 2011 | Wild Planet Room Gear Atm Safe Bank
Need to reset electronic safe
i have changed batteries and pressed the reset button but it still wont open any ideas thanks karen
Jul 22, 2009 | Kitchen Appliances - Others
Need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Apr 06, 2009 | Safe International Digital Electronic Safe...
Locks & Locksmithing Logo
118 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
