Question about Exercise & Fitness
From where I can buy a display for my motorized gear life treadmill ?
  • 3,957 Answers
It may be difficult to get a replacement display. Have your manufacturer make and model information and contact one of the following:
http://www.treadmilldoctor.com/?gclid=CjwKEAjw65GqBRCj3fLFwK2SpWoSJABa3E3cNMqfrd6JPyfCBK0YWVUETk10Y-O_z8VSOP3fPq-z7hoCZ17w_wcB
http://www.fitnessrepairparts.com/
Posted on May 02, 2015
  • Chantelle Cardona
    Chantelle Cardona May 02, 2015
    The buttons of the original display of my treadmill do not work. Do you think it can be fixed ? Because that's the only problem, the carpet of the treadmill is working fine I fact it's stuck on high speed !
4 Suggested Answers
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
anupam19
  • 263 Answers
SOURCE: I have life gear treadmill.
you need to recalibrate your meter
Posted on Mar 16, 2011
  • 3 Answers
SOURCE: On display stands: MOTOR COMM BAD
Try Carolina Technical Services in South Carolina for all you East Coast guys. They charge flat rate of $175.00 and have a 90-day warranty. Also great turnaround time. Carolinatechnicalservice.com. 864-504-7303. Sure beats sending to California and having to wait for 3 weeks.
Posted on Jul 04, 2011
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
The term immobilize is on the display panel, how do I get rid of that and get it working again
When necessary to immobilize the treadmill, set display to read SELECT A WORKOUT. (Press the STOP Key
twice if not already there). Then hold down the SPEED DOWN Key and press the STOP Key. The treadmill
now displays IMMOBILIZED. In this state, the treadmill cannot be operated. The main motor and incline are
disabled. The treadmill will remain in this state across resets, power cycles, etc. To restore normal operation,
repeat the same key sequence: hold down the SPEED DOWN Key and press the STOP Key. The treadmill will
display SELECT A WORKOUT again.
Apr 11, 2013 | Life Fitness T5-0 Treadmill
The incline on my HEALTHRIDER treadmill wont decrease. Help please!
1) tight the flexible cord from keypanel vs display board
2)tight the display board vs lower board(main motor board)
3)Test the main motor board(faulty to worn deck belt)
4)INCLINATION motor burn.
5)Adjust Pot from the inclination motor
6) the gear slip adjust or repair.
see the block diagram
Jun 29, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
When you press Quickstart it says "Please Wait" and it stays like that for about 2 minutes then you can begin workout? Not sure how to fix.
I have seen this a couple of times. The incline motor probably has a gear problem. Remove hood and find the plug for the incline motor, disconnect and then reset treadmill. treadmill should work but will not incline until incline motor is repaired or replaced. Good luck.
Oct 13, 2010 | Life Fitness 95Ti Treadmill 95 Ti
Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Apr 28, 2010 | Life Fitness 9000 Next Generation...
Jan 29, 2010 | Life Fitness 9500HR Next Generation...
I have a life fitnes treadmil. The read out says
u would have 2 buy a new motor controller communication board and replace the old 1 its very difficult
Jan 23, 2010 | Life Fitness 9100 Next Generation...
FET Error
FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
Nov 08, 2009 | Life Fitness T3 Treadmill with Advanced...
Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Oct 13, 2009 | Life Fitness T3 Treadmill with Advanced...
Life fitness treadmill display: transistor error-won't run
Solution
Feb 28, 2009 | Life Fitness Remanufactured Next...
Exercise & Fitness Logo
47 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
