I print a copy there are appear meganta thik line in printing what is problem?
SOURCE: copies print with horizontal lines
thin lines? spaced about 1.5 inches apart could be toner left on the drum, take the cartridge out turn it over and retract the shutter, manually turn the drum using your thumbs on the edges of the drum, do you see thin lines on the drum? sometimes something sticky gets on the drum attracting toner and then it transfers to the paper during the copy process
Posted on Dec 21, 2007
SOURCE: Wide black line down middle of paper
I have same problem, with new ink cartridge, also tried cleaning the print head, no luck.
Posted on Jan 15, 2008
Ajkill
  • 2035 Answers
SOURCE: two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Posted on Nov 11, 2008
SOURCE: Print Problem - vertical lines
I have MFC 7820N. Noticed same problem as other when making copies. Vertical line used to appear.
Open the Scanner where you can see the glass - Flatbed ( where you put the documents to copy)
Make sure that Glass is Clean.
Now make there is Glass on left side about 1x9 inch. Make sure this glass is clean. I had rubbery stain on that I had to rub it off.
Vertical line does not appear when I make copy from Feeder or Flatbed.
Posted on Dec 15, 2008
leroyal
  • 2120 Answers
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Posted on Mar 10, 2009
Black lines are appearing when i print and copy from my kyocera 1130
Your print head or some of the mechanism has something stuck in it causing the line. I would start by cleaning the print head if possible, if not you will probably have to replace the print head, but I would clean it good before I bought a new head.
Col.Dana Gillespie
Nov 29, 2014 | Kyocera Fs-1130Mfp A4 Mono Multifunction...
HP Photosmart C6100 All-in-One
Just click below;
Set Up the Printer Hardware
Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. s.gif » Product Specifications
Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
Generic printing instructions. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
hope this may help;
Regards,
VOTIT
Jul 31, 2008 | HP Photosmart C6100 All-In-One Printer
Officejet pro x476dw vertical lines after print
Run the "clean inkjets" routine followed by test pages until printout appears correct. Maybe the print cartridges are defective.
Aug 06, 2014 | HP Officejet Pro X476dw Wireless...
I print a copy there are meganta & cyan thik line in printing what is problem?
Id say magenta and cyan drums are bad if I had to guess. Whats the model? Whats the life count on your transfer belt?
May 06, 2014 | Konica Minolta bizhub Office Equipment &...
Poor image or a white line appear horizontally along the copy printed
clean or replace the "photoconductor kit" this usually connect with your toner
Jan 02, 2014 | Canon ImageRunner 2535i Copier
Line is appearing on the printed copies. How to
Is it a white or black line?There can be a piece of paper in the drum cartridge or the drum is damaged!Scratched!Try replacing the drum cartridge!Good Luck!
Dec 07, 2010 | Laser Canon imageCLASS 8180C Multifunction...
Facing copying problem from scanning section
Although you didn't specify the scanner model, this solution should work.
If the scanner has a top feeder, open it.
You will see a thin strip of glass, either to the left, or right of the large scanner glass.
There is most likely a small spec of ink, white out, etc on it.
Clean the strip glass with rubbing alcohol and the line should go away.
Apr 09, 2008 | Office Equipment & Supplies
26 people viewed this question
jasbo
jasbo
