How to figure 12x12 sq ft - Heating & Cooling
  • 1,631 Answers
Actually, if you are trying to size an air conditioner for a room, the calculation is in theory correct as Terry quoted. But accurately:
Measuring the room... length x width x height
12 x 12 = Square Feet of the room - 144 Sq. Ft.
144 x height of the room = Cubic Feet of the room
Posted on May 05, 2015
  • 991 Answers
12 x12 = 144 sq ft
12 x12 x12 = 1728 cubic ft
Posted on May 02, 2015
What is 12 by 16 in square feet?
12 by 16 what? Feet, inches, meters, etc?
Assuming you mean feet, it's 192 sq. ft.
Mar 08, 2017 | In Office Equipment & Supplies
How many square feet are in .014 of an acre. I'm buying it for 6.00 a sq ft.
From what I could figure that would be around 609.84 square feet.
Jan 19, 2017 | Garden
I need to know how much stone in tons I need to fill 8.5 acre at 1.5 ft depth
Stone is approximated at about 2700 lbs. per cu. yd.
An acre is 43560 sq. ft.
8.5 acres is 370260 sq. ft.
There 9 sq.ft. per sq. yd., thus there are 41140 sq. yds. in 8.5 acres.
A cubic yard is 3 feet by 3 feet by 3 feet (LxWxH).
Since you are only going to be at 1.5 feet, each square yard is equal to 1/2 cubic yard, so to figure the cubic yards divide sq.yds. by 2, thus you get 20570 cu. yds. of stone.
20570 x 2700 = 55539000 pounds. Divide by 2000 to get tons:
55539000/2000 = 27769.5 tons.
Nov 16, 2016 | Office Equipment & Supplies
How o figure sq ft of my home and bedroom
a square foot measurement is the product of the length by the width (breadth) or the room or building
If the room is 10 ft wide by 10 ft long it is 100 square feet in area
If it 10 ft long by 30 ft wide it is 130 square feet in area
really this is grade 1 maths
so to make it easy for you ,take a tape measure and measure the dimensions and multiply them using a calculator and the answer is in square ft
Jan 30, 2016 | Heating & Cooling
I need the formula for figuring square feet, say a 12 x 25 foot square---Need to know how much paint would be needed?
12 x 25= 300 sq ft.
Divide that by whatever the paint can says the coverage is.
if paint says 1 gallon covers 200 sq ft then u need 1.5 gallons
Apr 03, 2015 | Miscellaneous
Convert 30pounds per sq.foot to pounds per cubic foot(concrete=150#/cubic foot at 1in. thick conc. slab).
These are not the same, so cannot be directly converted.
Pounds per sq ft is a measure of pressure, while lbs / cu ft is a measure of density, weight per unit volume.
I think maybe what you are doing here is converting the weight of concrete in a 1" slab, where a sq ft would contain
1 x 1 x 1/12 = .0833 cu ft
The figure of 150 lb/ cu ft is correct for the average density of concrete, so the above slab would have
1/12 x 150 = 12.5 lbs/sq ft at 1" thickness
BTW that is a thin slab of concrete, insufficient even for a light-duty pathway. If you are referring to a screed for tiling or similar, that is cement.
Mar 01, 2015 | Office Equipment & Supplies
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 | Garden
Kenmore model 795.7500401 need to know cu sq ft
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Aug 27, 2010 | Kenmore 71279 Bottom Freezer Refrigerator
Heating & Cooling Logo
176 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
