What is the component that is immediately after mains lead called
  • Washing Mach... Master
  • 3,957 Answers
It depends on the manufacturer make and model. Can you provide a picture of the item you need reference to?
Posted on May 02, 2015
What is the plug in part for xbox one called
That's a good one some say it's a 2 pin kettle lead or a 2 pin power lead or 2 pin mains lead hope this helps if you go on eBay you can buy the right one here is what you are looking for 371542608628 this is the item number for the Xbox mains lead only ok
May 14, 2016 | Video Game Consoles & Games
Vermeer 605l baler belts
If everything is powering on and no error messages are being thrown out by your machine on the console then this can very well be that you have a bad Drive Motor.
You can test the drive motor separate from any other component by disconnecting its leads from the Main Board. Making sure to disconnect the machine from power and removing the main shroud of course.
All you need is a 12V cordless drill battery or any 12V battery that you can manage connecting the Drive Motor leads to.
If the motor turns on immediately after you connect it straight to the battery then the problem with the belt not moving is in your Main Circuit Board BUT if does not turn on when you connect it to a battery then you definitely need a new Drive Motor.
Please only perform these tasks if you feel comfortable doing so and at your own risk.
If you do not feel comfortable enough doing any of these steps and need us to find a technician in your area we would be happy to do so or if you just have any questions for us we are available :)
By phone 888-713-2880 or by chat at www.sportsmith.net
We look forward to helping you ! Otherwise, good luck with the repair :)
Aug 30, 2015 | Exercise & Fitness
The moment i start the fuse goes off changed nearly three fuses
probly the noise supressor capasitor folow mains lead into back of mechine u will have mains lead going into it 2 other going out of it to mech components good place 2 start good luck tom.
Sep 20, 2014 | Whirlpool duet Washing Machines
Tv cutting off immediately
Check and replace its main digital board. There should be any shorted component/s on it. This board is not repairable. Only card base replacement can be done. Contact a service technician.
May 24, 2013 | Insignia IS-LCDTV32 32 in. Television
Will not function unless plugged into mains, says battery is fully charged
How old is the battery? It may be time to replace it? Always use a genuine replacement.
Apr 29, 2013 | Computers & Internet
Zenith tv :no power
Check and replace shorted component/s on its main board.Check all the components in the horizontal output section.
Sep 13, 2012 | Zenith Televison & Video
My tv suddenly wont turn on. it powers on by itself then immediately goes off then starts the same cycle again. I checked the capacitors and non of them are blown. any ideas. when the tv tries to start, i...
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
or
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here.
Aug 20, 2011 | Toshiba 50HP66 50 in. Plasma Television
Dear repair team, I have a Mackie FR1400 power amp, about 12 years old and always been very reliable. On Saturday at a gig, it stopped working completely and blew the mains fuse and all the mains...
It wont be fixed by friday It appears a number of components have failed in the amp If it's not the main transformer , you're looking at $200-300 for a fix
Dec 06, 2010 | Mackie Audio Players & Recorders
I have Peavey Pv 2600 Power Amplifier ,the B side did not work sound did not come
One side of the amp has failed and repair is NOT DIY. Take it in for servicing. This amp has many components in the power amp and repair is complicated. A failure can lead to 20 components being damaged. Failure to replace all damaged ones can result in immediate failure destroying the replaced ones.
Aug 28, 2010 | Peavey Pv 2600 Power Amplifier
Wavy lines across a samsung dlp hdtv. repairman said it needed a new set of digital and analogue cards and would cost us about $1000
How old is the tv? if its being used for more than one year, what you should do is, ask a technician open the item and see on the main board and see if theres any crack on the soldered lead at the terminal of any components in the PCB. if there is, its called a cold sold. You re- solder ( dry sold) the terminal of the components. Do it to any visual crack or cold solder terminals and test.
Hope it helps.
Nov 06, 2008 | Televison & Video
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
