Question about Kitchen Appliances - Others
Rises only halfway. Bakes well. Stirs well. Doesn't rise. Is it a temperature thing?
    Master:
  • 918 Answers
Could also be not enough yeast or not enough salt. Test the yeast before using as it may be too old. Try a teaspoon with a few drops of water .and if it's usable it should bubble a little. Also may not be enough liquid. Be sure to measure and follow directions exactly. good luck
Posted on May 02, 2015
  • 460 Answers
Could be stale yeast or poor bread flour.
  • Irene Tulloch May 02, 2015
    Could be stale yeast. Or poor bread flour. Never use fresh yeast in a breadmaker and always put the ingredients in following the order given in the manual.
The bread won't rise like it used to. Not the yeast. What's wrong with the machine?
Is the the flour? Have you tried different recipes and does the same thing happen? Too much salt can prevent rising, or not using rapid rising yeast. good luck.
Apr 30, 2015 | Kitchen Appliances - Others
Error code E000003-0001on Canon ir C3220
this is problem with the thermistor .
because the fixing temperature doesn't rise. maximum rise up to 70 degrees C.
solution is change the thermistor with a new.
Jul 21, 2011 | Canon imageRUNNER C3220 Color Copier
When my machine goes into the next to the last rise I have a loaf about 5' but then when it goes into the last rise before it bakes it never rises high again. The finished loaf is about 3 1/2" high....
Not fully understanding this but it sounds like you are opening the lid too much and spoiling the rise. Only open the lid when at the dough stage if necessary.
Bread will not keep warm, it will steam and go wet and soft in the pan. Open the lid when the cycle has finished and remove the loaf.
Try re-setting your machine by holding down the start button till the display goes out.
Jan 28, 2011 | West Bend 41048 Bread & Dough Maker
My bread maker kneads twice just fine, and it bakes just fine, but the bread doesn't rise very high. All of my ingredients are fresh. I have tried several different recipes and it still doesn't rise in...
That is a difficult problem. One thing you might try to get a better rise in your machine is to cut the salt in your recipe by one half. It's healthier that way too. Please let me know the result.
Jan 07, 2011 | Oster 5838 ExpressBake Bread Maker
Tempature gauge doesnt rise like it should
Mostly likely being the temperature gauge isnt going to the normal position usually indicates a problem with your engines thermostat, this problem with the thermostat usually is accompanied by poor heater output so if your heater isnt getting as hot as it use to chances are your thermostat is opening to soon or is stuck in the open position which is why your temp gauge isnt rising to the normal halfway point like it should...
Dec 07, 2010 | 1998 Plymouth Breeze
My temperature has been rising in my saturn if i sit very long in traffic. What could this be?
As long as the temperature isn't spiking and the fan is turning on. It is normal for the temperature to rise to halfway on the gauge and then for the radiator fan to kick on. Sitting in traffic will normally do this.
May 21, 2010 | 2000 Saturn SL
Bread not rising.
The yeast you have may be too old or it has not been properly activated prior to using.Yeast requires warm conditions to work correctly. Hope this helps.
Dec 21, 2009 | Kitchen Appliances - Others
Its copier (ir2016j)to desply writh system error. wath is this problem?
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation err
Dec 17, 2009 | Canon Office Equipment & Supplies
The freezer temperature changes sporadicaly. It
The temperature would charge due to change of cycles in the refrigerator operation. For example, the temperature would slowly rise if the compressor has shut off. Also, the temperature would rise significantly during the defrost process. A heater is activated at the evaporator coil to thaw the ice that forms there. This heat would transfer to the freezer unit and would cause the temperature to go up.
As long as the cycles are constant, and the temperature does not rise significantly and keep rising for a long period, there is no problem.
Oct 19, 2009 | Refrigerators
Kitchen Appliances - Others Logo
127 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
