Question about Sewing Machines
Why does machine keep missing stitches - Sewing Machines
  • Sewing Machines Expert
  • 460 Answers
Skipped stitches are normally caused by either, a bent or dull needle; using the wrong size needle for the fabric or the machine is incorrectly threaded.
Posted on May 02, 2015
What is the rght tension for The Elna Contessa 410 sewing machine?
Every machine is different, so a "right" tension will vary. The factory standard tension setting is the midway point between high & low number...BUT that needs to be tweaked per your machine.
Skipped stitches? Be sure to use a brand new needle and a needle that is compatible with the thread and fabric you are sewing. (Replacing an old needle is the most common and least expensive fix for a lot of machine problems.)
Optimal tension is when the upper and bobbin threads meet in the middle of the fabric.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Feb 24, 2017 | Elna Sewing Machines
I have a Hyundai 8 stitch sewing machine and have great difficulty sewing with it. The thread keeps bunching up underneath and misses a lot of stitches. I have followed instructions, both threading up
here is a suggestion for the skipped stitches
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
and since it stops with a crunch,, I suggest having the machine
checked to see why that happening
Feb 18, 2013 | Sewing Machines
It wont stitch tee/shirt material it misses stitchs
If machine misses stitches consistently, it can be several things.
Needle not installed correctly, not threaded correctly, Bobbin case not installed correctly, make sure the bobbin itself is inserted correctly and spinning in the correct direction.
Finally, machine may need service the timing is off. All actions of a sewing machine are carefully "timed" to form a stitch while sewing. Sewing things that were too heavy for the machine or you hit the bobbin case while sewing can knock the machine out of adjustment.
Let a professional do the maintenance on your machine. Some may opt to show you how to do more in depth maintenance yourself at home.
Cheers,
Feb 01, 2013 | Sewing Machines
I keep missing a stitch
Skipping stitches can be caused by a bent or dull neeedle or a needle that is not suited for the fabric you are sewing on.
Feb 08, 2012 | Brother LS-2125 Mechanical Sewing Machine
When sewing the machine keeps missing stitches and isnt sewin properly massive big stitches
Try a new needle first if that does not work email me and I will attach timing instructions but tell me what make of machine you have, drivewithken@blueyonder.co.uk
Apr 10, 2010 | Sewing Machines
My machine misses stitches. have changed needle, cleaned machine, still missing stitches
Your machine needs to go into the shop for service. Take a sample of the stitching for the tech to evaluate.
Mar 19, 2010 | Husqvarna Lily 540 and 550
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
