Question about Frigidaire Dryers
I have a Frigidaire electric dryer it won't start and beeps three times I'm not sure what year and make
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Frankie, thank you for your inquiry!
Based off what you have described your Frigidaire dryer is not starting and will only beep three times. This could be a possible issue with your control panel or sensor. I would recommend performing a reset on your washer and you can do that by unplugging the power cord for at least ten minutes. You may also want to check your household circuit and assure that the breaker did not flip or that the circuit has not shorted. If that all appears to be in proper working order then I would suggest consulting with a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Posted on May 06, 2015
  • 1314 Answers
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
Posted on Jan 24, 2008
Illeagle
  • 525 Answers
SOURCE: Frigidaire electric dryer
I was unable to locate a similar complaint through my service database, so this is going to be a hit or a miss answer.
This model has an electronic control board in it and it is possibly picking up a static discharge from your body and powering up the start relay. This may be due to improper grounding or a recent power issue. This type of failure apparently does not happen with a 240 volt appliance often enough to be in the books. I might suggest that you unplug the dryer for 10 minutes, then plug it back in to see if it corrects the problem. If not, you will want to have your outlet inspected by an electrician. You may also have to replace the control board, if the electrician finds the outlet satisfactory. You may also just want to consult a factory authorized servicer that would be capable of checking the outlet AND testing the board before replacing it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 20, 2008
  • 1214 Answers
SOURCE: Fridgidaire dryer beeping and flashing lights
Download the troubleshooting instruction sheet here ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134509400efs.pdf
Follow the instructions and reply back what you determine and I will help further.
Posted on Jan 28, 2009
protek480
  • 1723 Answers
SOURCE: GLEQ2152ES0 - Frigidaire Gallery series electric
Inside, the drum rides on rollers that support it. The bearings fail and will squeak. The noisy one will have to be replaced. You will have to open it up and try to locate the noisy one.
Posted on Jul 20, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
My Frigidaire dryer beeps 3 times
If it beeps three times, but does not start, it "thinks" the door is open, you must test the door switch circuit... Door Switch 134813601
Jul 08, 2016 | Frigidaire Dryers
Frigidaire FEQ1442CESO wont stop beeping
Mine did the same thing. It started right after the warranty ran out. I dealt with it for a long time until 1 day it wouldn't stop running. I saw a couple internet posts about defective circuit boards in this model so I got brave and took mine apart. Once I got the board out and examined it I found 7 or 8 cracked solder joints, including the main power supply to the board. I reheated them with a soldering iron and added a little bit more solder to a couple of them and now my dryer works like the day it was new.
Jun 14, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer Beeping
Woah? Crazy machine you got there. You should try unplugging it or reseting it, if that doesn't work, contact ur nearest washing mashine place or fix place.
Dec 16, 2013 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire dryer faqe7001lw blinking lights
Try resetting the computer like a cars e.c.m. by turning the dryer on and plugging it from the outlet. It worked for me once w our new Malta front loaders
Apr 07, 2012 | Frigidaire FAQE7001LW Dryer
I'm pressing the start button but the dryer won't start. it just beeps about 3 times then stops. The first time i tried it it ran for about 5 secs then shut off.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 21, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Dryer beeping three times and lights flash, dryer will not start
I have this problem too, I have noticed that when this happens the moisture is high within the dryer. Usually when I open the door and let the steam out and let the dryer cool a bit it stops, but would still like to know why it really is doing this.
Feb 14, 2010 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire FEQ1442ES dryer beeping three times and flashing lights. How do I stop it. Have removed and cleaned lint screen and the cage.
I have the same problem with the same dryer, but don't know why either. I was reading on one posting that a button might be stuck so the dryer thinks the button is constantly being pressed.
Jan 16, 2010 | Frigidaire FEQ1442ES Electric Dryer
Dryer turns off after 30 seconds and beeps six times (over and over.....)
other than a good lint cleaning by dissasemble and if not then replace the motor
Jun 23, 2008 | Frigidaire FEQ1442ES Electric Dryer
Dryers Logo
116 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
