Ctv astron 2955 flyback parts number - Televison & Video
No image astron CRT TV model rc-2132
Service Manual free download schematics datasheets eeprom bins pcb repair
Loose solderings or a
damaged fuse because of a failure in the horizontal (flyback circuit) a flyback capacitor and or shorted linetransistor because a part of the tripler can be bad and have
high voltage that passes through overloaded somewhere leaking on cable and more and get somewhere earth
Jul 16, 2016 | Televison & Video
Ctv 2955 flyback number
number assigned to the fly at fly city marathon
May 02, 2015 | Televison & Video
Why doesnt 2955 tractor air blower come on?
check for loose ground wires in the circuits.
Aug 13, 2014 | Garden
Engine number is illegible.
engine size is listed in 2 places..the emisions tag if the motor is original to the car..or get the numbers off the block..the parts store can tell with those numbers..in some cases the engine size is also in the cars vin number..also look for a part nuber like off the alternator or some other thing,,ac pump etc..does the title show it??mine does
Dec 09, 2013 | Cars & Trucks
In ctv picture tube heater is spark how to do ?
Hi voltage transformer(Flyback) is damaged. It needs to be replaced
Sep 19, 2013 | Televison & Video
What is the service mode of astron model ctv 2955
help nman po..bka my value kau na ic 7522CS audio ng astron tv model no.ctv-2955 burado kc unang letter..
Feb 28, 2012 | Televison & Video
Flyback transformer part number
the number printed on the flyback transformer is also the part no. for details u have to mention model no., also the number printed on flyback T/F
Sep 03, 2011 | Samsung Televison & Video
EHT Faliure and kindly give me the alternate EHT details .
Hi Rayjanardank
Eht on all modern ctv is generated with in the flyback transformer , although some older tv set use a triplier unit feed with a 8kv pulse from the flyback transforme
To find out the one that you have got , if the flyback transformer as two controls A1 and Focus mounted on it then the eht is generated inside, if the Focus contol is mounted on the tippler unit unit .As you do not state the make mod No of tv i cannot be of any more assistant but you could cheek the A1 voltage on the crt base , if this is about 350/430volt then the eht should be ok. Hope this might help with your problem.
Regards windyhouse.
m.
Dec 03, 2010 | Televison & Video
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
