Question about SteelSeries Siberia v2 - Headset ear-cup STEELSERIES
Right ear cup stopped working suddenly! No damage..no hits!
    Master:
  • SteelSeries Master
  • 996 Answers
Right speaker blown
Posted on May 02, 2015
    Top Expert:
  • 10,875 Answers
Broken internal wire
Soul by ludacris left ear cup problem
BEst to just try to find a repair shop for that sort of thing. Disecting headphones is a risky venture, and 9/10 it results in a frustrated, headphoneless user.
Jan 30, 2014 | SOUL by Ludacris Bolt Signature Series...
Bose Bluetooth Headset Series 2 - Right Ear
What exactly happens when you say the battery drains fast? Does it suddenly stops working, or does it starts beeping with low battery notification right away?
If the battery is bad, then you will need to have it replaced. Although the bluetooth is made to be a single piece without easy way to service it, it can be done, although with some skill.
One day I will post detailed instructions on how to service this type of device, but from what I know these types of posts BOSE corporation takes down very effectively, that is why you do not see any of them.
If the bluetooth suddenly stops working and then starts up again, that most likely is a actual switch problem, and requires cleaning inside the switch. I say cleaning instead of replacement, because I failed so far finding switches of this type. It is about .7 mm high, about 5 mm long and 2.5 mm wide. If you are careful, you can open the switch, clean the inside moving parts of it, and solder it back up again. I have done so with at least 20 of them, so I know it is doable.
Oct 28, 2012 | Bose Bluetooth Headset Series 2 - Right...
Keurig coffee maker won't stop, end up with 4 cups all at once
Timer section and valves open due to incorrect assignments. Replace or repair.
Sep 16, 2012 | Keurig B100 Coffee Maker
Hi, I have a bose on ear headphone which i bought 2 years ago. It was working great till suddenly the right side stopped working. i am sure this is because of the internal wire but i am not able to...
The earpieces of the Bose headsets are tightly sealed and it will be difficult to open without damaging the edges. you need a sharp flat edge knife or screw driver to wrench open the lids and get access. You must be gentle and try to wrench the sides carefully as it can be a very tight fit.
Apr 05, 2011 | Audio Players & Recorders
I have had the bose in-ear headphones for a year and they were great at first and then all of a sudden the left earpiece stops working. If I move the part that connects the headphones to the ipod then it...
If your headphones are in warranty (under a year old) Bose will repair or more likely replace them with a new pair. I am now on my forth pair or Bose in-ear headphones and experienced the same problem with an ear piece stop working. I have to say Bose customer service has been fantastic and has replaced each pair. Every new pair is then covered by a new full years warranty. Unfortunately my fourth pair has just gone wrong with the same connector problem. Bose again have said they will replace as they are in warranty. I have been told if they are out of warranty they will offer a new pair at a discount price of £50 instead of £80. However i think that if my new pair go wrong out of warranty i will have no option but to look at alternatives.A Pair of headphones that cost £80 should last more than a year!!!
Mar 29, 2010 | Bose in-ear headphones - Black with...
How do you get the rear u-joint out of the drive shaft on 2005 chevy avalanche
It will need to be pressed out.
Universal Joint: Service and Repair
Nylon Injected Ring
Universal Joint Replacement - Nylon Injected Ring
^ Tools Required
- J 9522-3 U Joint Bearing Separator
- J 9522-5 U Joint Bearing Spacer Remover
Disassembly Procedure
Notice: Never clamp propeller shaft tubing in a vise. Clamping could dent or deform the tube causing an imbalance or unsafe condition. Always
clamp on one of the yokes and support the shaft horizontally. Avoid damaging the slip yoke sealing surface. Nicks may damage the bushing or cut
the lip seal.
1. Support the propeller shaft in a line horizontal with the table of a press.
2. Mark the propeller shaft as to which end is the transmission end and which end goes to the rear axle.
3. Place the universal joint so that the lower ear of the yoke is supported on a 30 mm (1 1/8 inch) socket.
4. In order to shear the plastic retaining ring on the bearing cup, place J 9522-3 on the open horizontal bearing cups. Press the lower bearing cup out
of the yoke ear.
5. If you do not completely remove the bearing cup, lift the cross and insert J 9522-5 between the seal and the bearing cup you are removing.
Continue to press the bearing cup out of the yoke.
6. Rotate the propeller shaft. Press the opposite bearing cup out of the yoke.
7. Mark the orientation of the slip yoke to the tube for proper reassembly.
8. Remove the cross from the yoke.
9. Remove the remaining universal joint parts from the yoke. If you are replacing the front universal joint, remove the bearing cups in the slip yoke
in the same manner.
10. Inspect the retaining ring grooves for plastic.
11. Inspect the bearing cup bores in the yoke ears for burrs or imperfections.
12. Clean the remains of the sheared plastic bearing retainers from the grooves in the yoke.
13. The sheared plastic may prevent the bearing cups from pressing into place and thus prevent the bearing retainers from properly seating.
Assembly Procedure
1. Remove the bearing cups from the universal joint.
2. Assemble 1 bearing cup part way into 1 side of the yoke.
3. Turn the yoke ear toward the bottom.
4. Assemble the cross into the yoke so the trunnion seats freely into the bearing cup.
5. With the trunnion seated in the bearing cup, press the bearing cup into the yoke until the bearing cup is flush with the yoke ear.
6. Assemble the opposite bearing cup part way into the yoke ear.
7. Ensure that the trunnions start straight and true into both bearing cups.
8. Press the opposite bearing cup into the yoke ear while working the cross all the time in order to inspect for a free unbinding movement of the
trunnions in the bearing cups.
Important: If there seems to be a hang-up or binding, stop pressing, and inspect the needle bearings for misalignment in the bearing cup.
9. Press the bearing cup into the yoke until the bearing retainer groove clears the inside of the yoke.
10. Assemble the bearing retainer in the retainer groove.
11. Continue pressing until you can snap both retainers into place.
12. If seating the retainer is difficult, spring the yoke slightly with a firm blow from a dead blow hammer.
13. It may be necessary to lubricate the snap ring with a slight amount of chassis grease so the snap ring seats in the bearing cup groove.
External Snap Ring
Universal Joint Replacement - External Snap Ring
^ Tools Required
- J. 9522-3 U-Joint Bearing Separator
- J 9522-5 U-Joint Bearing Spacer Remover
the lip seal.
2. Mark the propeller shaft in order to show which end connects to the transmission and which end goes to the rear axle.
3. Disassemble the snap rings by pinching the ends together with a pair of pliers.
4. If the ring does not readily snap out of the groove in the yoke, tap the end of the cup lightly in order to relieve the pressure from the ring.
5. Place the universal joint so that the lower ear of the yoke is supported on a 30 mm (1-1/8 inch) hex head socket or a 27 mm (1-1/16 inch) socket.
6. Place J 9522-3 on the open horizontal bearing cups. Press the lower bearing cup out of the yoke ear.
7. If you do not completely remove the bearing cup, lift the cross and insert J 9522-5 between the seal and the bearing cup you are removing.
Continue pressing the bearing cup out of the yoke.
8. Rotate the propeller shaft. Press the opposite bearing cup out of the yoke.
9. Mark the orientation of the slip yoke to the tube for proper reassembly.
10. Remove the cross from the yoke.
11. Remove the remaining universal joint parts from the yoke.
12. If you are replacing the front universal joint, remove the bearing cups in the slip yoke in the same manner.
13. Inspect the retaining ring grooves for dirt, corrosion, or pieces of the old ring.
14. Inspect the bearing cup bores for burrs or imperfections.
15. Clean the retaining ring grooves. Corrosion, dirt, rust, or pieces of the old retaining ring may prevent the bearing cups from pressing into place o
Assembly Procedure
2. Assemble 1 bearing cup part way into 1 side of the yoke. Turn the yoke ear toward the bottom.
3. Assemble the cross into the yoke so that the trunnion seats freely into the bearing cup.
4. With the trunnion seated in the bearing cup, press the bearing cup into the yoke until the bearing cup is flush with the yoke ear.
5. Install the opposite bearing cup part way into the yoke ear.
6. Ensure that the trunnions start straight and true into both bearing cups.
7. Press the opposite bearing cup into the yoke ear while working the cross all the time in order to inspect for free unbinding movement of the
Important: If there seems to be a hang up or binding, stop pressing. Inspect the needle bearings for misalignment in the bearing cup.
8. Press the bearing cup into the yoke until the bearing cup retainer groove is visible over the top of the bearing cup.
9. Assemble the bearing retainer in the retainer groove.
10. Continue pressing until both retainers can be snapped into place.
11. If the retainer is difficult to seat, the yoke can be sprung slightly with a firm blow from a dead blow hammer.
12. It may be necessary to lubricate the snap ring with a slight amount of chassis grease so that the snap ring seats in the bearing cup groove.
Oct 30, 2009 | 2005 Chevrolet Avalanche
Flip up ear speaker stopped working
Sounds like the ear piece connection between the two halves of the phone has been broken. Your "speaker phone" function should still work because the sound comes from the back of the main body of the phone. To the best of my knowledge, this can't be fixed. You will need a new phone. I hope this helps.
Mar 29, 2008 | Sanyo Katana SCP-6600 Cellular Phone
No sound on right side
I had such a problem, but I fixed it.
Plase see video on YouTube:
or read this brief text explanation:
Under/behind the ear sponge are four screws - 3 black screws, that holds ear cup closed, and one silver cup, that mounts small piece of plate, that holds the cord.
Gently unscrew, open ear cup, and then first I suggest to check if circuit on that small circuit board is not broken! You can also check wires, etc.
DawidWarsaw
Mar 12, 2008 | Pioneer HDJ-1000 Professional Headphones
Bose QuietComfort2 Acoustic Noise Cancelling Headphones not working
same thing has happend to me, sometimes when im playing around with it i get about 2 hours use before it turns off again. do you recon its worth sending it off to bose for repair?
Oct 05, 2007 | Apple Bose QuietComfort 2 Acoustic Noise...
SteelSeries Siberia v2 - Headset  ear-cup  STEELSERIES Logo
77 people viewed this question
Top SteelSeries Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a SteelSeries Radio Communication Expert? Answer questions, earn points and help others
