Question about Sony Cdk 3300, 60 Disc Auto Load, Cdg Karaoke / Cd Music Jukebox W/ Video Mixer
It's actually a mega room sys. Cd selector for disc will not turn
Hi I have a Sega Megadrive 1 & Mega CD 1. It has wroked for years from new but it has got a problem within the last week. When turned on the conosles comes on as normal and you see a good and...
Well, Sega's aren't known to be long lasting, but if it isn't an issue with the console itself you could try checking all of your cords, assuring they are plugged in good and tight to both your console and screen. Faulty cords can easily be overlooked. If your discs aren't working, but you're hearing the music from different ones and no picture, it sounds like an issue with one of your video jacks, so make sure everything is properly plugged in.
Failing that, bring it to a retro gaming shop to have it looked at or test it at someone else's place.
Mar 01, 2011 | Sega Mega-CD Console
File sys error
you can try with the disc format of the cd, not dvd format. The difference between DVD and CD is the color of the disc surface. see the result if the result is the same when read DVD discs? if the result is the same it indicates that the optical lens is defective. if otherwise is only a DVD laser beam that has been weakened or defective.
Jul 26, 2010 | Coby TF-DVD5605 Portable DVD Player with...
Mega CD 1 loading problem
Yes, but get ready to take it apart. The gears are out of alignment that operate the CD mech, and also dried out. Lithium grease helps it, keeps everything lubricated well. When you hold it vertically the things all move on the inside slightly but they go back again when you set it back down. Look at any washers and where gear shafts or other parts sit.
Apr 13, 2010 | Sega Mega-CD Console
Press Esc to cancel loading SPTD.sys
You should be able to boot XP from an install CD and perform a repair install (not a complete install) which will not affect your existing files.
You'll need to enter your BIOS and ensure that your PC is set to boot from CD, then restart your PC with the disc in the disc drive. After a period of loading, it will give the option to repair install on the installation screen. Choose that option, then follow the onscreen prompts and allow the install to finish before rebooting (rebooting may be automatic, depending on your version). After repair install, ensure that all updates are current.
Dec 30, 2009 | Microsoft Windows XP Professional SP2
Hi,my mega cd console has stopped loading discs,is there a simple fix for this or is the laser dead
well it could just be dust on the laser you may want to open it and look at the laser and see if it turns on if it does then it just something in the way of it
Nov 12, 2009 | Sega Mega-CD Console
Cd room doesnt work. it doesnt see any discs.
actually the problem is from inside ,,,sometimes the cd room wires gets loosen up or if the wires gets breaken ups your computer will not detect any cd room discs ,so you need to call a hardware guy and you need to fix it
Nov 27, 2008 | HP Computers & Internet
No play
Sounds like the drive belt that spins the disk is slipping or broken. You have only one actual cd reader so no matter what slot the disc is in it has to go to the same cd reader drive.
Hope this helps...
Dec 27, 2007 | Technics SL-MC7 110-Disc CD Changer
Sony Cdk 3300, 60 Disc Auto Load, Cdg Karaoke / Cd Music Jukebox W/ Video Mixer Logo
79 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
