Question about Snapper Garden
I have a snapper that will start but will not stay running
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 103 Answers
Clean the carb, may need a carb-kit
Posted on May 17, 2015
New snapper will start but wont stay running this started to happen after I used contaminated gas
best thing to do is drain the gas and blow out the fuel lines. take the carburetor of and clean it real good with carburetor cleaner. there is something in the bowl interrupting fuel flow.
Mar 11, 2017 | Snapper Garden
Snapper SPX lawn mower will not stay running
How long does it run? Could be fuel filter, dirty carb, timing/valve issue, etc.
Jul 30, 2016 | Snapper Garden
Have a brand new snapper push mower used once now it won't stay running when set down flat to start cutting what's wrong with it
what do you mean set down flat? it should always be set flat. if you had it tipped over or standing on end that's why it wont run. take out the spark plug and try to start it a few times. with the plug out it wont start you just want to blow out any oil or gas that may have got in the cylinder. put a new spark plug in it. it should run now.
May 08, 2016 | Snapper Garden
Why will my Snapper riding mower NOT go into gear? forward or reverse?
what kind of snapper... RER ( rear engine rider ) tractor style, model number will help greatly here because snapper has made mowers since the dawn of time !!!
Aug 23, 2014 | Snapper Garden
SR1642 Snapper rear engine, what is the fuse for?
Most the fuse is for starting. The park brake probably has a safety switch. It needed adjusted.
Jun 24, 2014 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
My snapper mower wont stay running
Sounds like the carburater needs cleaned or rebuilt.
Apr 15, 2013 | Garden
Snapper mower
If the hand brake is on that will also kill the engine.
Oct 30, 2017 | Snapper Garden
Snapper Big Six Mower. New spark plug, cleaned carburetor&fuel tank, new 91 octane fuel mower starts with engine starting fluid but won't stay running
Try taking the float bowl off and clean out the orfus. It will eather be in the nut holding the bowl on or in the end (sides) of the pickup tub the nut scews on.
Jun 30, 2012 | Omega Rear Drive Wheel Snapper Mowers
Snapper riding mower carburetor floods engine it wont stay running
The carb. is working. Get a carb. kit and in it. They don't cost much.
Mar 30, 2012 | Snapper Garden
Snapper lawnmower will not start - sparkplug is good, air filter clean, no idea what is wrong
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the vertical intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jul 05, 2010 | Omega Rear Drive Wheel Snapper Mowers
Garden Logo
121 people viewed this question
Top Snapper Garden Experts
ray gallant
Thomas Perkins
Thomas Perkins
mburke3
Are you a Snapper Garden Expert? Answer questions, earn points and help others
