If antina's socket is damage what should we do? i opened tv but damage part fix in tv i cant undrstand what should be do?
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
Contact any service technician. This part cannot be fitted by a user.
Posted on May 02, 2015
TV-Toshiba model 24HV1OE. I plug headphone to a Service use only at the back of my TV and something went wrong, my TV screen becomes black, no picture and no sounds but has a power I cant turn it off
You might have plugged your headset to the service socket of your TV. Didn't you notice it? Just beneath that socket, marked as "Service use only"? Done a great mistake. Contact any service technician. The main digital board [system control memory section] might have damaged.
Sep 18, 2016 | Televison & Video
How to i connect my Tv with RCA antina for local tv shows ?
Attach the antenna lead to the connector on the back of the set which should be marked ANT or something similar
Apr 11, 2013 | Toshiba CF32H50 TV
No channel coming on screen
this tv needs a digital to analog converter box in order to recieve the digital tv channels that currently exist.
I unplugged tv to move it across the room now it wont turn back on??
POE:
  1. Connect tv directly to socket without any powerboards and make sure the power cord is properly inserted (if it works than any powerboard you have been using is probably faulty)
  2. Try a different power cord
  3. See if socket is dead using another appliance. If another appliance works then the Tv is probably damaged (refer to warranty if applicable)
  4. if other appliances don't work in that socket check your fuse box.
  5. If fuse box is fine then try a different socket (if it works you may need to get an experienced person to fix the socket your trying to plug the tv into)
Dec 20, 2010 | Televison & Video
Beautiful picture,no sound
Hello
If your TV displays good picture and there is no sound output from it, please connect an earphone or headphone to its headphone/earphone socket, if provided, and check whether the sound output comes from it or not. If there is sound output from the headphone socket, and not heard from the speaker of your TV, the speaker inside your TV may got damaged. Check the speaker of your TV. For that you have to open the TV. Unscrew it and go for the same type and number and replace it. There is an other possibility, that is if your TVs headphone socket itself can got damged. You can make sure it by after checking your speaker. If the speaker is alright; the socket is faulty. Replace it with same type.
An other fault can occur is Audio Output Ic failure. If it has damaged, you won't get sound output either from speaker or from the headphone socket. You can make sure about it. Keep your ear very close to the speaker side of your TV, switch on the power to TV. If there is a "Thumb" soud is heard, you can make sure that your TVs speaker is Ok, and if there is a "Hum' sound also comes from it, Output Ic is damaged.
If so you have to open your TVs back cover and locate the Audio Output Ic. It can be located by following its speaker wire. The speaker wire goes to Output Ic. Usually it may be screwed into a metal heatsink. Desolder it out of the board, and go for the same type and number. Replacing it will solve the problem.
All the precautions must be taken before opening your TVs back cover. Plug it out from the wall socket bfore doing this. Keep chldren away from you, and not let them even stand beside you. Let an adult be there beside you as a precationary measure.
Read and understand well the above said solutions and go on.
Wish you sucess.
Oct 23, 2010 | RCA 27V514T 27" TV
E71 Pro Tv mobli dual sim
well it's a hardware problem then u need to replace your phone antina...........or just replace your phone
Nov 21, 2009 | Cell Phones
Grundig PVR/ Digital TV Tuner with no external antenna?
i am living in a house where i cant place an external antina. is there any reveiver that donot require exteernal antina and we can receive channens
Jun 27, 2009 | Televison & Video
Audio
If you are electrically minded I cant think of another solution apart from to open the set and de-solder the socket from the board and then you might be able to gain better access to the stuck pin. Some of the sockets are open at the back enabling you to poke something through the gap so you might be one of the lucky ones. Please remember to take all necessary precautions while working on the tv especially the discharging of capacitors as a spark from one of those could do a lot of damage to the tv or yourself. If you open up the set and it looks too complicated please dont feel like you have failed just put it back together and find a competant technician. Good luck.
Oct 04, 2008 | Toshiba 26WL46 26 in. LCD Television
6102i
Dear check the signal status if there are no signal then may be the antina tips are not touching with the board on antina pad for this reassemble the phone tight the screws. if signal come and go no come agian then its prob from hardware take is to technician.
Feb 13, 2007 | Nokia 6100
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
