Question about Miele Washing Machines
My laundry has come out of the drum all covered in black marks. Anyone know what's wrong? Thank you
    Top Expert:
  • Miele Master
  • 42,108 Answers
If the machine is more than a few years old and you use powder instead of liquid detergent, the marks will be old detergertent powder breaking loose and soiling the washing
Posted on May 02, 2015
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
Hi! I have a Maytag Neptune front loading washer machine. On a few occasions I have found a small amount of water in the drum before starting my weekly laundry. Today when I went to start my laundry...
This is symptomatic of a water control valve not closing completely- its no power/fail position is closed.
Whichever it is, hot or cold, needs replacing!
Service call ;-0(
Good luck,
John C
Mar 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
Loud squeek and catches clothes between the drum and housing and makes black marks on laundry
It sounds like the felt pieces which guide and help to support the drum are worn out. If you get the full model number you should be able to order them at www.appliancepartspros.com Good luck.
Mar 10, 2010 | Kenmore 62872 Electric Dryer
During the spin cycle, it sounds like a helicopter. So noisy that you have to leave the room and close the laundry room door.
This is difficult to work out as there are so many different symptoms. Here are my thoughts -
Dust from carbon rushes is black. Grey dust usually comes from a loose concrete weight. Loose tub weights are rare on this model but they cause a loud knocking noise which is often worse when the washing machine is revving up to spin and dying down from a spin (suspension problems are also often worse at this stage too). It's not normally a metallic sound though.
If the noise is coming from the motor banging against the sides of the machine then it will make the machine move when it happens. The whole machine may jump or move to one side. The motor often thumps the side of the washing machine on Hotpoint washers where the motor is fitted at the top of the tub and over to the right hand side. This is a daft place to fit a motor and only Hotpoint / Credo did it. I think they've eventually stopped now though.
It is normal to be able to push the drum to the side so that the motor hits the casing. If the suspension has gone, the tub should be twisted and leaning to one side more than the other or it just could be very loose. It's difficult to check suspension if you don't know how it should feel.
If the noise is coming from the inner drum hitting the heating element or throwing an object like a £1 coin (trapped between the inner drum and the outer tub) around, then the washing machine will be stable but the noise would still be a horrible metallic knocking. This is one because I suspect.
If the carbon brush is charred (as in these Hotpoint & Credo carbon brush pictures) then it's definitely faulty and needs replacing. This could cause the machine to bang about violently on spin but it normally wouldn't.
As for the clothes being covered in black marks. (Washing (laundry) is still dirty or has marks on it (marks on clothes) ). This sounds potentially ominous as it could be that the inner drum is catching on the inside of the outer tub which is often covered in gunge. As clothes are pushed through the holes in the drum on spin, this could cause them to scrape on the inner tub and pick up greasy marks. Check for play in the drum by lifting it up and down from the front. It should only lift up a mm or so. Then turn the drum so that one of the drum paddles is at the bottom. Pull the drum toward you at the point of the drum paddle. It shouldn't have any play in it. Turn the drum round and test the other two as well. If the drum spider and shaft has a crack in it then one or more of the arms will allow excess play when you pull the drum at the paddle points.
Carbon dust from a motor could never get onto clothes.
Thank You for using Fixya.com
Aug 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Black streaks on my laundry
Marks on clothing in a washer are usually caused by a reaction between detergents and fabric softeners, especially cheaper bargain brands.
If you are sure that the black streaks are getting on the clothing in the washer versus the dryer, it could also be oil from the transmission getting into the washer tub. See if the spots will come out using a petroleum distillate of some kind. (paint thinner, etc). If a petroleum distillate will remove the marks, it is most likely something petroleum based that is making the marks.
This is a rare occurrence, and most marks on laundry are caused by the dryer. Typically, the drum rollers wear out and rubber and metal filings can get into the dryer and mark/streak clothing. Hope this helped and sorry for the problem you are having. Best wishes.
Jul 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Printing blank pages
Hey,
Try installing the toner/pc drum once more, then print something and when printing open first cover and take out pc drum, look the pc drum, if the pc drum is clean, then the laser wount reach it. laser is located above the pc drum. when you close front cover then there is a little swich in right side what opens laser cover, try to makse sure that it works.
if there is a print marks in pc drum, hten the problem is in transfer rollerits located behind the pcdrum.
Oct 05, 2008 | Konica Minolta PagePro 1350W Laser Printer
Black streaks on the fax
Yes it does, the rubber blade that cleans the drum is not doing its thing properly, hence leaving your mark, pull the drum unit out and expose drum by pulling back the cover underneath it, you should see your mark on the drum, don't touch drum with fingers or brush/clean it, it is photosensitive too so keep away from light for any period of time.
Oct 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Black Marks on Clothes Coming out of the Dryer
Follow-up the Nov 28 post: Just got my replacement dryer after many phone calls to LG. The installer told me that the black marks were from using dryer sheets. He said the ozone system in the dryer breaks down the chemicals in the dryer sheets. Doesn't explain why the problem seems to be fixed when roller and drum is replaced then returns after about 2-3 months.
Oct 09, 2007 | LG DLE2514 Electric Dryer
Black marks on clothing at completion of drying cycle
Is the residue coming from the back or front of the drum? Most dryers are equipped with 2 drum roller supports in the rear under the drum. You may have a drum roller that is going bad and some of the rubber residue is getting past the drum seal. Some dryers are quipped with an additional pair of drum rollers under the front of the drum as well. I would check all the drum rollers to see if they are all in good shape. A definite symptom of a bad drum roller is finding black residue along the outside of the drum where the rollers ride. You will have to open the dryer cabinet to see the outside of the drum. Also, check the rear drum seal to make sure it is not crimped or folded inwards in the drum. The felt seal in the back should should ride evenly all the way around the drum and should not be that visible inside the drum itself. That is, you may see some of the seal, but you shouldn't see part of it folded inside the drum or bits of it tattered or torn. I hope this makes sense to you. Let me know if this helps.
Jul 06, 2007 | LG DLE2514 Electric Dryer
Tumble Dryer
how do i fit felt gasket on front of dryer?
Oct 10, 2006 | Zanussi TD4100W Electric Dryer
Washing Machines Logo
74 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
