Question about Freezers
The freezer does not freeze anymore - Freezers
  • Freezers Master
  • 744 Answers
Hello Rina;
My name is Peter. I am a retired field service technician.
You need to provide more information.
Upright freezers are very simple.
There is a label on the side wall witch has your model number on it.
1.) Locked in the defrost mode - If nothing is running except for the light being on then you are locked into defrost. Your defrost timer is in the back behind a metal plate. With a large flat head screw driver slowly turn the shaft clockwise one click at a time to turn the freezer on. If it turns on this component will have to be replaced.
The freezer does not freeze anymore - 25676024-2tl4mzw4ix4qkonroxm2e5ag-2-0.jpg Cost: $20.00
2.) Is your freezer cool? You may have a frozen drain and cooling coil. Un plug your freezer and leave the door open for 24 hours. After several hours check to see if you have water build up in the bottom of the freezer. If so, you are going to need to keep soaking up water unit there is no more.
3.) Can you hear the cooling fan running? These fans are $35-65.00.
4.) You may have a bad thermostat, bad defrost heater, or a refrigerant obstruction.
I need more information from you to determine the problem and the model number.
Posted on May 02, 2015
My ignis chest freezer isn't freezing anymore even
your cooling system matchine facced this problem.
Mar 20, 2013 | Freezers
Why does my upright freezer run constantly but it's not freezing anymore
what you need is a new Compressor,w/o Electricals part number 5304475092
Jan 14, 2013 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer doesn't freeze anymore. Runs like a
On a chest freezer , the coils are located inside the walls of the freezer . The heat normally felt on the outside is the condensor coils inside the wall. The coldness felt on the inside is from the evaporator coils also inside the freezer wall .If the inside of the freezer has over 1/2 inch of frost , then defrosting may work . If NO frost on the inside , possible leak in the coils which are not accessable . Only solution is to replace the freezer . Anyone can buy refrigerant 134a which is what your freezer uses .
Jul 15, 2010 | Danby 3.6 cu. ft. / 102 liter Chest...
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not working well ....
CONTROL SWITCH PROBLEM
May 20, 2009 | Freezers
Whirlpool model EV201NZRQ, stoped freezing,lights are on, compres
in leaving the door open you may have over heated the compressor and not it is not pumping enough freon anymore
Dec 11, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Fridge not cold
I had the same problem with fridge/freezer and repair man told me NOT to use anything that has been in freezer as what is happening is that it is constantly freezing and defrosting because there is not enough gas in the system to cool the appliance. It is possible to re-gas the appliance but service engineer advised me to claim a new fridge/freezer from company which I did. Please do NOT eat anything from freezer as could make you ill.
May 01, 2008 | Freezers
Frigidaire Upright not cooling
Not enough information but  if you are refering to the compressor as the black housing below, it seems that the compressor is either seized or burnt out.
Oct 25, 2007 | Frigidaire 11.6 cu. ft. / 328 liter...
Freezers Logo
254 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
