Question about LG Televison & Video
My LG DVD/CD receiver Model:LH-D6246,Shows disc 'error' when I load a dvd or cd disc but the radio plays very well please help
    Master:
  • LG Master
  • 996 Answers
Faulty dvd reading lens,should be change by expert professional
Posted on May 02, 2015
SOURCE: Check disc
Change your DVD player
Posted on Jun 28, 2008
  • 4 Answers
SOURCE: LG V8824w DVD/CD - Disc Error
I bought a lg lst3510A at a yard sale for 20 bux. Lady said that it was new and had never been used. Plugged it in and got disc error when trying to play a dvd. I removed the cover and gently slid the lens pickup to the far back I DO MEAN GENTLY.... IT SEEMS LIKE IT HAD LOST ITS HOME POSITION. This worked for me. IF YOU TRY THIS MAKE SURE THAT YOU UNPLUG THE DVD PLAYER FIRST. Good luck and I hope this works for you.
Posted on May 08, 2009
micromaster
  • 3614 Answers
SOURCE: My LG, HDD/DVD recorder Model DBRH1979 cannot read
using a dvd/cd cleaner, clean the optical lens of the unit, it could be some dirt that make the player not to read every cd you inserted.
Posted on May 30, 2009
seabelow
  • 95 Answers
SOURCE: My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
Posted on Jun 12, 2009
ginko
  • 19396 Answers
SOURCE: A Sony RDR-GX210 DVD player I can play a CD -
Hi Allan,
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
In your case the lens does not work on DVD , but only on CDs for the reasons above , that is quite common.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Posted on Sep 08, 2009
Testimonial: "Haven't tried it yet - but will let you know if successful thanks - Allan"
My LG LH T 6340 shows " no disc" when I load dvd. but music cd working properly. Is it problem with reading lens or something else?
The DVD and CD are read with 2 different lasers through the same lens. If you can replace just the lens/laser assembly then you will fix the problem.
Jan 12, 2017 | LG Televison & Video
Where can I download a manual for my LGCD/DVD Receiver Model LH-D6246 or can you tell me how to adjust the picture colour, Thank you Rob Manning
Hi Robert,
First of all, thank you for posting your question here at Fixya.
Please email me at mjsvillanueva23@yahoo.com, I will send you the copy of LG LH-D6246 Manual. File is in Pdf format (6.8MB), it can't be uploaded here.
Again, thank you so much!
Have a great day!
Mjsazon
Jan 10, 2012 | LG LH-D6230 System
DVD PLAYER 3166 SHOWING NO DISC
I AM HAVING A DVD PLAYER 3166 . MY DVD PLAYS CD /VCD/MP3/JPEG AND USB. BUT WHEN I INSERT A DVD VIDEO IT SHOWS NO DISC ERROR. BUT CD IT ACCPTING.KINDLY HELP ME OTHER WISE TELL ME WHERE SHALL I GET IT REPAIRED . PLEASE GIVE ME THE PHONE NOS OF PHILIPS CUSTOMER CARE THANKS, G.SEKARAN, CHENNAI
Aug 26, 2008 | Televison & Video
Problem playing DVD's
bring (cd cleaner)cd from near radio shack and run it until you get good result.
Jul 05, 2008 | Panasonic SA-HE90 Receiver
DISC ERROR MESSAGE
Usually it helps a lot if you take off the upper case of the DVD player (7 screws) and search for the lens of the DVD/CD. Clean it with alcohol or terpentine or something like that and it will probably work afterwords. Good luck.
Jun 22, 2008 | LG LH-C6235 System
Audio playback
1.bad rca jacks
2.could be connected to wrong audio lead rca jack
3.the settings in dvd player donot match the receivers example- dts or ntfs
4.make sure its regioned to your player some audio isnt on the disks
5.pc's usually have new cd formats that came out
cd's and dvd's for some reason in this age isnt being able to play fully in older equipment do to the change in cd/dvd formats which makes you go out and buy new equipment it happened to me not just 2 weeks ago bought a new dvd and found out it wouldnt play in my year old dvd deck had to go out and buy new dvd deck then disk and all my others played fine
May 11, 2008 | LG LH-D6230 System
Lite On LH-18A1P DVD RW
I have two LITE-ON DVD DRW LH-18A1P on drive (E:) and drive (F:) It has gone from everything working great to not being able to burn a DVD. When placing a DVD into either (E:) or (F:) it shows up in my Window's Explorer as a CD drive.... Only allowing me to burn a CD in these drives.... Can play past burnt DVD's though in both both drives.... hve tried a couple of different brand disc, LG and TDK and get the same message appears 'to please insert a dics', need help I do!!! lcs2
Running Window's XP
DVDMy LITE-ON DVD DRW LH-18A1P
Oct 09, 2007 | Lite On LH-18A1P DVD RW Dual Layer Burner
Check disc
May 23, 2007 | LG DE9523P DVD Player
Televison & Video Logo
101 people viewed this question
Computer Repairing
Computer Repairing
