TV was switched on yesterday and is since showing Factory sign across the screen. what is the reason and how can it be removed >
  • Kevin Prendergast May 03, 2015
    Hi Nienke van den Bovenkamp, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Need make and model#
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
The set is in factory mode now. You have to turn this mode to normal. The details will be with its service mode options. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Posted on May 03, 2015
Why is my LCD TV not powering on after resetting to factory settings?
Kindly study the operation manual and follow instructions for installation from the beginning. You may have to switch off the TV manually, switch off power, remove plug, wait for sometime and retry this.
Jul 30, 2012 | Toshiba Televison & Video
"Guide" button makes Sony Bravia TV go to black screen
I am having the same problem with my newish Sony Bravia. There is only a black screen when I use the "GUIDE" button. And individual channels show "No program description".
Did you ever figure out the problem?
Thanks.
Jul 10, 2010 | Sony Televison & Video
Acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to...
acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to factory defaults. please help
Dec 24, 2009 | Acer PD100 Multimedia Projector
Tv shuts off after screen goes red
Good Day sir, the reason why your tv act that way is the switching power supply. The power supply regulator, cannot supply the current needed by your TV. these can be caused by several factors. a faulty switching regulator, low power, or filter capacitor leaking, check the voltage across the VCC after the regulator, if possible the switching transistor. and the ic that controls the pulse they are usually near each other. for safety reasons, better consult your service personnel. hope this helps. if you need more assistance, do let me know. thanks
Jul 28, 2009 | Televison & Video
Panasonic TV-Sound but no picture.
    According to the symptoms, There is a problem in vertical out section.Just check it there must be a capacitor that has been burst or leak.And second one reason could be the malfunctioning of vertical IC.Which is also in the vertical section.
Thanks for using fixya.
Dec 01, 2008 | Panasonic CT-27D12D 27" TV
WT-46809 Inputs show lines across screen
1. THE SYMPTOM IS BRIGHTER IMAGE ON THE SIDES AND DARKER IN THE MIDDLE. THE PROBLEM CAN BE WITH RED BLUE AND/OR GREEN. CHECK FOR PROPER CONNECTIONS TO THE "DAG COATING AND CONNECTIONS TO PIN 9 ON THE SOCKET OF THE AFFECTED CRT. MAKE SURE THESE GROUND POINTS ARE COMMON WITH CHASSIS GROUND.
Apr 25, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Konka TV
if you have an owners manual there is a special feature menu yu can go to that will fix how your picture fits on the screen. my tv was doing the same thing except it was the top and bottom until i played around with the remote and stumbled across the menu.
Jan 02, 2008 | Konka K2001UM TV
26PF5521D wont show menu after reseting factory defaults
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
Oct 26, 2007 | Philips 26PF5521D 26 in. HD-Ready LCD...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
