Question about JDM Honda CR-V CRV 07 08 09 2007 2008 2009 Front Bumper Sport Mesh Grill Grille
How to turn off AFS warning on front panel
AFS lamps blinking. On/Offbuttom don`t work?
Afs light blinking
Adaptive Front lighting System (AFS) is used when for example if it was day time and you entered a dark parking garage the lights would detect and adapt to the lighting environment which will then automatically trigger the Bi-xenon headlights to turn on themselves in order to illuminate the road ahead when the vehicle anticipates it is necessary. It is an automatic feature which turns on by itself for your convenience therefore you wont have to induce any actions, the car does it all for you. And most Importantly (I quote) "the Adaptive Front lighting System (AFS) automatically controls the headlight lighting pattern according to steering angle and vehicle speed to help provide better visibility at night You will need to see the dealer on this, the part that causes this is dealer only
Jul 01, 2016 | 2008 Lexus IS 250
Where is the emergency flasher relay located on 2013 Rogue?
Here is what the service manual says. Looks like it is not a flasher relay but a function of the body control module.
TURN SIGNAL AND HAZARD WARNING LAMP SYSTEMSystem Description OUTLINE Turn signal lamp and the hazard warning lamp is controlled by combination switch reading function and the flasher control function of BCM.
TURN SIGNAL LAMP OPERATION - BCM detects the combination switch condition by the combination switch reading function. - BCM supplies voltage to the right (left) turn signal lamp circuit when the ignition switch is turned ON and the turn signal switch is in the right (left) position. BCM blinks the turn signal lamp.
HAZARD WARNING LAMP OPERATION BCM supplies voltage to both turn signal lamp circuit when the hazard switch is turned ON. BCM blinks the hazard warning lamp.
TURN SIGNAL INDICATOR LAMP AND TURN SIGNAL SOUND OPERATION - BCM transmits the turn indicator signal to the combination meter with CAN communication while the turn signal lamp and the hazard warning lamp are operating. - Combination meter outputs the turn signal sound with the integrated buzzer while blinking the turn signal indicator lamp according to the turn indicator signal.
HIGH FLASHER OPERATION (FAIL-SAFE) - BCM detects the turn signal lamp circuit status by the terminal current value. - BCM increases the turn signal lamp blinking speed if the bulb or harness open is detected with the turn signal lamp operating. NOTE: The blinking speed is normal while operating the hazard warning lamp.
Oct 13, 2014 | 2013 Nissan Rogue
I just replaced the lamp on my Panasonic PT-50LC14. Now when I turn the power on it blinks green for about 1 minute, then it blinks red. The screen never shows a picture. Not sure what to do, but I am
Have you done the lamp time reset procedure; before and after replacing the lamp? I thinks, you haven't. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 13, 2014 | Panasonic PT-50LC14 Television
Afs mean lexus
Switch labelled 'AFS OFF' is down near the fuel door release.'AFS' means Adaptive Front lighting System (at night with the Bi-Xenon headlights) it swivels either side, pressing that button means they stay pointing straight ahead and don't turn when you turn the steering wheel. You need to push the button again to turn the AFS back on.
Oct 06, 2013 | Cars & Trucks
My blinkers just stay turned on without blinking both left and right, what should I do to fix this?
There should be a flasher fuse for the turn signals, chk. owners manual if you got one, it should have a listing diagram for the fuse panel, or at least show you wear to locate it.
Dec 05, 2009 | 2002 Chevrolet Camaro
2004 Lexus LS430- AFS light is blinking all time, headlights goes up when started and aimed correctly now. Couple of months ago, I took the positive terminal off the battery to reset the AFS light but did...
you need a scan tool to clear the fault code before the light will go out, but a health check should be performed to see if any other problems exist.
Oct 03, 2009 | 2004 Lexus LS 430
Hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
Feb 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Jan 10, 2009 | Samsung DLP HL-P5663W 56" TV
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
JDM Honda CR-V CRV 07 08 09 2007 2008 2009 Front Bumper Sport Mesh Grill Grille Logo
21 people viewed this question
Top C-mod Vehicle Parts & Accessories Experts
Tom
ivan whisker
ivan whisker
Richard Warren
Richard Warren
Are you a C-mod Vehicle Part and Accessory Expert? Answer questions, earn points and help others
