Question about Janome MB4 Four Needle Embroidery Machine
Needles lock have all correct threads in the machine test run 3 needle locked tried 1st that lock also just had it fixed sewed a lot and now jammed i have had nothing but trouble would like to use as it cost a lot of money,a free new one would be nice
  • 4 Answers
Have you hit a hoop while sewing? Is the needle jammed up and will not come down or down and will not go up? You need to make sure that you have no thread in the bobbin area. Even a tiny little piece will lock it up. Have you kept it oiled ? There are several places that need oiling. Bobbin area and needle bars are the two main ones. Make sure your needles are all the way up
sometimes the screws will vibrate loose on the needle bar .
Posted on May 02, 2015
Needle thread does not pick up bobbin thread on my baby lock sewing machine
check needle thread tension is tight enough
you may have to check the needle / hook timing as if that is not correct , the hook will not be positioned to pick up the needle thread to make the loop
take it in to a sewing machine repair shop for a service
Feb 18, 2017 | Baby Lock Sewing Machines
How can I fix this problem on the Necchi sewing
That bird's nest of a jam is very frustrating! Here are a few checks to make.
1. Ensure that the upper thread is threaded correctly, that is, that all the guides are engaged in the correct sequence.
2. Ensure that the upper thread is firmly settled between the tension discs and in the take-up lever.
3. Double check that he needle is inserted correctly.
4. Ensure that the bobbin is inserted correctly ... the thread is spooling off in the correct direction. This is very important.
5. Ensure that the bobbing thread is locked in the tension spring.
6. Make sure that the presser foot is in the down position as you begin stitching.
Oct 12, 2014 | Sewing Machines
Machine Locked
Hi, First of all, make certain you remove both parts of the needle. Sometimes it breaks under the plate and knots up with the bobbin. If that is so, lift the presser foot and carefully try to lift the plate so you can get scissors under it to cut the thread and free the needle. Pull the bobbin out and replace it and put a new needle in. It should work fine.
Feb 04, 2014 | Consew 7360R-1 Mechanical Sewing Machine
How can I tighten the bobbin tension?
try adjusting the top thread tension
here are some link for a manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125_EN_272.PDF
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125i_EN_1628.PDF
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Mar 01, 2013 | Brother LS-2125 Mechanical Sewing Machine
Singer 9030 runs but don't sew
try changing the needle--make sure the needle is the correct one
for the fabric being sewed.
also make sure the needle is turned the correct way in the needle
holder and pushed all the way up into the needle holder.
Nov 08, 2012 | Singer Sewing Machines
I was sewing, turned the machine off to pin something, and when I turned it back on, it jammed in the bobbin area. It will only stitch one stitch and then jams. I have taken it apart over 30 times, and...
have you tried changing the needle-
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
check the thread take up lever-if the thread come off the thread take up lever that will jam the machine up--I've had it happen to me
Sep 13, 2011 | Euro-Pro Shark 9110 Sewing Machine
I can start working withmy baby lock, the needle brokes verytime i runthe machine , and i can not sew
If this machine has a needle position adjustment and it is on the center position -
and you are sewing a zig-zag stitch and using a presser foot with a narrow opening this could break the needle
and the needle plate is a single hole, this will break the needle.
and you are sewing a straight stitch with a new needle and it breaks, the machine needs to go in for servicing.
Feb 13, 2010 | Baby Lock Sewing Machines
Thread bunching and jamming in bobbin area
what you have is known as bird nesting and is from the needle tension not being tight enough
before you thread the needle pull the thread and the correct tension is when there is noticeable resistance to pulling the thread
always check adjustments using scrap material
Nov 11, 2017 | Kenmore Sewing Machines
Needle thread will not pick up bobbin thread
Needle may need to be changed. Be sure it is the correct needle for the machine.
Feb 18, 2009 | Singer 7462 Mechanical Sewing Machine
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Janome MB4 Four Needle Embroidery Machine Logo
109 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
