TDK Model NX-4CD-WHDS
Does anyone have a manual? Connector cable not staying in.
3 Suggested Answers
SOURCE: Instruction manual for TDK NX-03 CD Sound System needed.
I have a manual if you want to send me your email I'll will scan to PDF and send you a copy.
Posted on Jan 31, 2010
SOURCE: need a new connect main cable for nx 4cd where do
So do I. I'd like to find the answer to this question... not even TDK support can help me.
Posted on Aug 14, 2011
No audio output on the speakers of TDK NX-4CD.How do I troubleshoot?
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Dec 02, 2014 | TDK Audio Players & Recorders
NX-4CD CD is read but no audio out
You need to be more specific. What have you tried so far?
Sep 16, 2014 | TDK Audio Players & Recorders
Need a new connect main cable for nx 4cd where do i get one one broken pin in cable
Aug 16, 2010 | Audio Players & Recorders
Dec 16, 2009 | TDK Audio Players & Recorders
How do i get the tdk nx 03 stereo to play aux with no remote control
Did you get an answer to this question because I have the same problem. The remote is now broken and I have no way of changing it to AUX. If you know how, let me know.
Dec 05, 2009 | TDK Audio Players & Recorders
TDK NX-7CD not working
With some of the TDK NX models the 9 pin lead between the subwoofer unit and the control unit gets damaged in careless connection. Its not the most idiot proof connection out there and when the connector is not aligned rotationally with the socket and/or pushed in at an angle, the connection pins can get bent. Sometimes if there arent too many pins bent, the pins can be carefully straightened and when properly inserted, the unit will work perfectly. In most cases however, one, or maybe even two fuses in the subwoofer unit will blow. If the unit doesnt work in your case after correcting the lead issue, open up the subwoofer unit by removing the screws around the outer edge of the back panel of the subwoofer (about 10 screws) and carefully prize the panel away from the subwoofer box. Sometimes this may be difficult as the back panel is glued to the subwoofer box to varying degrees. Dont pull the panel away from the box too far as it is connected internally by leads, etc. You should find the two fuses on the circuit boards attached the the inside of the back panel, one for the input transformer and one for the amplifier circuitry. Replace them (**** Smith or Tandy electronics stocks them) and you should be in business. If it still doesnt work, there may be some additional damaged caused, but this is rare. If you need a new lead, Imation (TDK) will supply you one at a cost. Hopefully you can get it up and running as it is a great little HiFi.
Mar 21, 2009 | TDK Audio Players & Recorders
210 people viewed this question
 Grubhead
Grubhead
