Question about Briggs & Stratton Garden
Briggs & Stratton 33M777/21HP
Starter will not spin engine over compression-Battery and starter both tested, good order..mention of Automatic Decompression Device as aid to starting, no details in owner's manual, seeking technical manual I am a retired auto Mechanic, 50 years'experience, always refer to Tech Manuals for specific info--can you help here?
  • Briggs & Str... Master
  • 1,169 Answers
Check your valve adjustment first as these uses a decompressor that on the camshaft itself.
Now while checking the valve clearances as you go past TDC of the compression stroke there should a little bump on the intake valve when the decompressor is working. If this bump is not there and the valves are set correctly then the decompressor has failed and requires the cam to be replaced.
10 276781SingleCylinderOHV pdf
Posted on May 02, 2015
Bownes lawn tractor wont turn over. Battery fully charged and all safety switches were changed. its a briggs and stratton 12 1/2 horsepower
with a volt meter set to DC, pull the wires off of the starter solenoid coil (the small wires) and check for 8 - 12 volts DC at the wires when the key is turned. A poor connection at the solenoid coil will cause slow turning engine cranking or none at all.
If you have 8 - 12 volts there check for voltage to ground on the large cable that goes from the solenoid to the starter motor, one probe on the cable and the other on ground or ( - ) at the battery. Turn the key to start, if you have voltage to the starter motor but it does not turn loosen and retighten the mounting bolts to the starter motor and if that does not help do the same for the engine to ensure you have a good ground. If none of that works your starter motor needs to be replaced, if you have no voltage to the motor the solenoid or battery connections are faulty.
You can also quickly test starter health by conecting a set of jumper cables to a good battery, clamp the neg. to the engine block anywhere and tap the pos. to the starter cable connection from the starter solenoid, if the engine spins over your starter is healthy and the issue is certainly between the key switch and the starter solenoid.
Jul 07, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Sarter will not turn engine over
Two things cause this...a bad starter or weak battery...not sufficient Amps will not allow enough power to the starter to spin it fast enough to start the engine....a bad starter simply cannot use the power supplied it to turn the engine properly. Have some one do a load test on the battery..tests the battery simulating starting the engine. If ok it is the starter if not replace the battery..good luck.
Apr 09, 2014 | Briggs & Stratton Starter Briggs Stratton...
Ihave a vanguard 20 hp v twin on my snapper mower you turn the key and get like a kluk sounds like its coming from starter
Does it do it every time? First try and turn your engine by hand counter clockwise and try to start..sometimes the engine stops on a compression stroke and Is Under too much pressure for the initial start,..happened to my cub cadet laast week...,,if it turns and still gets a click...test or charge your battery..if it is ok you either have a bad solenoid or starter...first find the solenoid and croosing the two big post..it should spin the engine..if it spins it is your solenoid if not the starter is bad...not a hard job for either...both can be purchased at your local mower place...giid luck
Oct 24, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Engine won't stsrt as starter won't wind over past compression stroke. starter and battery good
check your valve adjustments, quite common for this to happen when the valves go too far out of adjustment.....it will work better with them adjusted too
Jan 27, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and Stratton Vanguard 23Hp starter issues
take the starter off and give the bendix a realy good clean up and then splash some oil on it,,,they get very dry and sticky at times,,,you can test the starter uasing some jump leads stand on it though, dont hold it in your hands as it will spin out of your grip
hook the black lead to the caseing and tuch the red lead on the starter battery stud,,,it should spin up and strow the bendix out as soon as you take the lead off the bendix should slid back in if it dont oil it till dose also check the starter relay it could be sticking on holding the starter in
Jun 06, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Starter spins but will not engage flywheel...
Check the flywheel for areas of damaged teeth also. Broken teeth on the starter drive gear may inticate damage to flywheel also.
May 20, 2010 | Briggs & Stratton Briggs Stratton Intek V...
New Vanguard starter only spins slowly even when
Did you ever get an answer? Mine is doing the same. I think the starter is toast. I bought a new battery, but spins just as slow. Thanks Ken
Jan 30, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
107 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
