Question about Garden
Locking door latch is missing some parts, need to know where I can buy a new door latch for this shed
  • Dennis Key
    Dennis Key May 03, 2015
    Hi Karen Fagundes, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
How do i refit the main oven door lock, i need a step by step guide or something?
Oven Door Latch (part #9761013) - How To Replace ...
? 4:32
https://www.youtube.com/watch?v=rbMZ8NgiKm8
Oct 31, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Door Latch 9761013 ... How to replace yourcooker hinges. - Duration: 8:50. how-2-repair.com 84,238 views. 8:50.
How To ReInstall Your Oven Door - YouTube
? 2:12
https://www.youtube.com/watch?v=EBhJk85mc1Q
Dec 28, 2010 - Uploaded by HavillFiles
Did you remove your oven door and now you can't get it back on? The manufacturers forget to tell you about locking the latches first! ... Oven Door Hinge (part #W10347466)-How To Replace - Duration: 9:25. ... Hygena / Whirlpool / Electrolux / Phillips ovencooker door removal (others with same hinge) ...
How To Replace an Oven Door Lock Assembly ' Repair ...
www.searspartsdirect.com/repair.../how-to-replace-an-oven-door-lock-as...
Main Menu; Recently Viewed ... This step-by-step range repair guide shows how toreplace the oven door lock motor assembly for a self-cleaning oven. The door lockmotor assembly locks the latch to keep the oven door shut during the ...
Jan 08, 2016 | Ovens
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
Can you provide any of the parts for this shed such as the locking latch?
Hi bumper to bumper in jule street has got just about any part u need u can speek to JP 0116076601 they can help u with parts
Jun 12, 2015 | Cars & Trucks
Hey , I have a 1997 t-bird and I need help getting a name for a part , I don't know how to fully describe it , but a part to my door latch broke , and it's keep the door from closing all the way , the only...
It's called the door latch. You can't buy parts for it. You can buy the whole mechanism though. Or get one at a junkyard. A spring or small pin has broken inside of it. I tried to many times to find parts for the inside of these things. No luck.
Nov 03, 2014 | Cars & Trucks
My door won't close at all bounces back a bad lock on a ford ka? i wil buy another lock but do i need to get the key of the new lock or i an stay with the one i have?
door lock latch is closed you need to release the locking mechanism at the side of door with screwdriver while holding door handle open to release the latch then door lock will operate as normal
Jan 20, 2014 | Ford Ka Cars & Trucks
The door mechanism is not locking, all the rest is working fine if you keep pulling the door shut. I got a new tilt lock (4812 4175 8398), but still not locking . The hook is stilly loose , but seems...
Hi Your door latch is bad and this is very easy to replace, First make sure the power is turned off , then removee the screws all around the door The door swich has a few wires going to it, unplug them and mark them , you will see small micro switches on this door latch they will need to be removed and put onto the new door switch , you can purchast a new door switch from this place i have gotten very good service from them , http://www.appliancepartspros.com/Appliance-Parts/whirlpool-dishwasher-door-latch-item-number-ap4481280.aspx this place has almost every brand name and they ship same day , good luck and this should be an easy fix Guy glipsky@tampabay.rr.com
Jul 26, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Wont work
Your door lock is not fitting correctly!
This is a safety override to make sure that the washer does not fill with water & leak all over the floor because the door is not locked properly!
Suggest you get the door lock mechanism checked out and adjusted. It could be that this has either become blocked with soap powder or cotton material shedded from your clothing over time.
The latch is normally available as a spare part, so you could check this out with your local Simpson dealer, or buy it on the internet once you know the part ref number.
Nov 17, 2009 | Office Equipment & Supplies
Rubbermaid Shed: Broken Latch (Part # HIP-046H)
Got to Rubbermaid's replacement part link below and fill out the form. Let them know that you need to replace an HIP-046H latch.
http://www.rubbermaid.com/SupportCenter/Pages/ContactInformationForm.aspx?ContId=72&Id=4
I filled out this form and received a better, metallic replacement latch in about 10 days. Hope this helps.
Dan A.
Sep 06, 2009 | Elite Rubbermaid Frameworks Outdoor...
1996 Ford Bronco door lock actuator
These directions might sound a little goofy. I'm trying to orient your location with front and rear rather then left and right because it depends on which door you are working on. Front is towards front of rig and rear, oh I think you get it.
1. Close window on door. 2. Using a flat screw driver pop off trim under inside door handle. I think there is a groove in the plastic to which the screw driver can be inserted. Remove screw. 3. Using same screw driver pop off trim panel with door lock and window control switches. Start lifting from end located at panel closest to the front of the rig. The panel towards the back end has a pivot point which holds the back of the panel into the arm rest. Dis-connect the two switches from the trim panel. 4. Again, using flat screw driver, pop off the trim pannel located at the upper door/window frame nearest the back of the rig. Remove screw. 5. Lift up the door panel to remove. Be careful the light bulb is attached to the door panel. Rotate light socket 90 degrees and remove. 6. From the rear of the door pull back the platic stick-on barrier. Don't remove the whole thing just pull it leaving about half of it towards the front of the door stuck on. 7. Remove the one 11mm bolt, located towards the bottom of door, which holds the rearwindow guide. Don't remove the two 11mm bolts which hold the horizontal brace. Nothing else needs to be removed, leave all rods and attachments in place. They all attach the the door latch and are not of any further concern.
8. Now the easy part. The actuators and door latches are separate components. The actuator slides onto the door latch via two metal guides located on the door latch. The actuator is held into place with a plastic locking tab. The locking tab is part of the actuator housing. 9. This tab has to be pushed in to release actuator from latch. 10. Find on ouside of door - rear where the latch fingers? (I don't know what else to call them) are located in the notched door frame. At the bottom of the notch is a very narrow opening, just a ****. This **** allows access to the locking tab on the actuator. 11. Orient the screw driver in the end of the **** closest to the interior. Working on a right door, looking at the locking fingers, facing the front of the rig, your screw driver would be inserted at the left side of the ****. Pushing a flat screw driver into the **** will push the locking tab allowing the actuator to slide off the door latch. 12. A flat screw driver or other small pry tool can be inserted between the actuator and the door lock to help slide the actuator off the metal guides. The pry unit can be inserted where the rod from the interior manual door lock stem is attached. Mine had a yellow snap/flip keeper. 13. The actuator slides off from the interior towards the outside door panel. 14. Simple put pressure onto the locking tab with one screw driver and gently pry with the other one and the actuator should slide right off.
15. I picked up an actuator at a u-pull it wrecking yard for five bucks and it worked fine. Dealer wanted $90.00 and auto parts wanted $127.00. When I pulled my actuator from the wrecked rig all door panels and interior where stripped. It took me literally 20 seconds to pull the actuator. 16. To install new unit slide actuator onto door latch rails and let locking tab click into place. You might have to manually move the interior door lock stem up and down until the finger on the actuator lines up with a hole on the plastic part of the interior lock stem.
16. I Want to thank TommyRox in Texas on Ford Truck World and rivguy on automotiveforums.com for their posts.
Jun 18, 2008 | 1996 Ford Bronco
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
