Question about Boating
Knocking noise in mid section when I gear on the trailer
Just had serviced not shure if they changed water pump sounds like drive shaft
SOURCE: 2003 cadillac cts drive shaft
I was driving my 2003 cts, and all of a sudden the power went out. Car want start and igintion and shifter is locked. Can this be the ante theft lock system, because i have an alarm system installed with the factory alarm?
Posted on Aug 21, 2009
  • 169 Answers
SOURCE: 2001 Pontiac Grand Prix Knocking Noise - Drive Train?
if it only knocks or clunks puting in gear or gettingonit I would check motor & trans mount both upper dog bone & cross bars to core support
Posted on Aug 30, 2009
SOURCE: banging noise
Drivesharft/rear Dif rubber mounting gone (propshaft bangs against outter mounting when demand more power. Need to replace mounting(s), parts cost about £30 average garage 2hrs work.
Posted on Nov 18, 2009
  • 2926 Answers
SOURCE: clicking noise while driving, changes with speed,
If indeed it is coming from the drive line area, it could be a bad universal joint. It may also be a torn boot on the front axle (just thought I'd mention this), or it could be the transfer case chain has a lot of slack, causing the chain to hit against the transfer case housing internally, this would be the worst case scenario.
Posted on Feb 05, 2011
dmroberts42915
SOURCE: Drive shaft makes noise as
As far as it making noise as it turns faster I would check your U Joints. The clank that you hear switching into 4wheel low is completely normal. I have had 3 big Chevy trucks and 6 suburbans. The dealer will also confirm. Just make sure when turning 4wheel low on the suburban is in Neutral at a complete stop, OR in neutral rolling at 3mph.
Posted on Mar 28, 2015
Can rocker arms cause heavy knocking noise
what is the motor from? Typically if you changed out all those parts already and its still a heavy knock, you're looking at crank bearings. How did you change the connecting rod bearings without the crank bearings? or are you referring to something else? I would assume its connecting rod bearings are the issue, if main bearings go you would see an issue in oil pressure.
Dec 23, 2017 | Cars & Trucks
2004 model 62000 miles problem engaging park when gearbox has been in drive for a while
i had same problem in my liberty figured out shifter screw is lose and shifter cover was free the pull out ,very small hole front mid section if you able to pull shifter cover from the main shaft if free just aling hole and screw new bolt and make sure you are pumping the brakes when changing the gears.
Aug 01, 2012 | 2004 Jeep Grand Cherokee
Knocking noise when reversing
check your lug nuts. also check the axle shaft joints.
Jan 02, 2012 | Nissan N Z 38 POWER CAT Cars & Trucks
I took my 2005 Chev. Malibu in for an oil change and now it is making a loud noise from the engine. they say its the water pump? is that possible?
  • Hi, I can help.
  • When your water pump goes bad it will begin to grind. I had one I let got far to long and it sounded deafening when I opened the hood. You can open your hood and listen and see for yourself. The water pump is on the belt line, left side under the hood, last pulley toward the rear.
  • Now if your asking can an oil change effect the water pump? No, not at all. Water pumps go sporadically.
  • It would be odd that you heard no noises before the oil change and now the water pump is loud enough to take notice after the oil change. The bearings usually go a little slower than that.
  • I would be interested in some more of the details to this. And what your overall concerns are. I'd be happy to further. help. Otherwise get a second opinion on your cars condition.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Aug 22, 2011 | 2005 Chevrolet Malibu
Why do i still hear a knocking noise in the water pump, when i just changed it. also my coolant pressure cap hoes that connects to the radiator blew off while i was driving, why would that happen after i...
Maybe it's not the water pump that is making the knocking noise.
Water pumps generally don't make knocking noises.
It could have a spun camshaft or main bearing if you hear a loud metal to metal knocking noise.
The coolant pressure cap hose that connnects to the radiator:
Is this an overflow hose that leads to an overflow tank? If so, the hose may have a restriction in it.
Aug 07, 2010 | 2001 Dodge Dakota
Truck making a knocking noise when turning getting a little feed back in steering wheel to. only 35,000 k when hard turn almost sound like its rubbing something or grinding. if shaking steering shaft it...
there is a problem with the steering shaft going to gear box 2 out of 10 trucks have this problem gmc and chevy ive done a few, its a dealer part, replace that first then see if the other rubbing noise is there, but the knock noise is the shaft, i had 2 with about that mileage they were out of warranty, good luck start there first.
Oct 31, 2009 | 2006 GMC Sierra Denali
Vibration/Whinning Noise while drivin
Check fuel pump pressure. sounds silly but my 1500 ram van did this 2 months . replaced a lot of parts then left me sitting on side the road. Cause was fuel filter and pump.
Apr 20, 2009 | Dodge Ram 1500 Cars & Trucks
4.3 vortec engine , engine noise, knocking or tapping on top of engine, not when cold , but starts noise when it heats up, and gets louder as it gets hotter and hotter!!! Sounds like noise is in the center...
The knocking or ticking is going to determine if it is in the top end, lifters, push-rod or rocker arm issue or the bottom end that would include pistons or bearings.
If it is a ticking noise, it will more than likely be a valve train issue.
If a knocking noise, piston or crankshaft related problem.
Attached is a web site that you can listen to a piston slap which is a known issue for your 4.3.
Listen to the noise and see if it sounds similar to your problem. A piston slap will generally sound as though it is coming from the central area of the engine.
Listen to the recording and let me know.
Regards,
Apr 19, 2009 | 1996 GMC Jimmy
Boating Logo
270 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
