Question about Asko T712C Dryer
I have cleaned the lint filter and condenser and advised but my problem is that as soon as I start the dryer it will work for about a minute or so then stop. what is the cause or fix if any?
    Master:
  • Asko Master
  • 996 Answers
Heat limiting fuse defective
Posted on May 02, 2015
Dryer stops too soon
if the dryer seems to be running fine check the vent line and the duct that the lint filter slides into,most likely if it takes to long to dry clothes lint is blocking the air movement somewhere,when was the last time you cleaned out the dryer and vent line,you should clean the dryer once a year so you don't have a fire and your clothes will dry on time,if the vent line is long remove it from the back of the dryer and blow it out with a leaf blower,remove the lint filter duct and clean it and vac out the cabinet where the motor is.
Apr 23, 2013 | Kenmore 63942 Dryer
Clean the Lint Filter or Condenser
check inside it may have a lot of lint build up in it, check the vent to outside and be sure there is no sharp bend in vent pipe to make it over heat. the straighter the better !
May 09, 2012 | Dryers
Why is my electrolux condenser drier overheating. have cleaned filters. will work for one load but needs a rest and cool down before the next load. If not ready and you turn it on too soon it appears to...
Have you checked the dryer vent tube that goes to the outside? It may have a clog in it (lint build-up). If it has a flex tube and it's bunched up behind the dryer it will clog and/or restrict the air flow causing heat build-up.
May 27, 2011 | Electrolux EWED65H Dryer
F4 is flashing on the led screen and the dryer does not work (intermitantly)
Too much lint in the lint filter, front housing, or in the condenser, Clean lint from lint filter and/or condenser
May 03, 2011 | Dryers
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal F3 which says to check condensation outlet and I have cleaned all the parts and cleaned hose but it will still beep after a few...
I have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Sep 22, 2010 | Bosch WTE86300 Electric Dryer
My dryer has a build up of water and give an F03 error. What can do to fix it?
Aug 08, 2010 | Bosch WTE86300 Electric Dryer
I recently had an ventless Bosch dryer installed (WTE8600US) and I keep receiving this message F:03 which the manual says "check hose for condensation outlet". any advice?
For the F:03 problem on the Bosch Axxis (WTE86300US) do all the things mentioned in Solution #1 above. Sometimes the lint in the condensation filter channels (those that run from front to back)can be quite stuck. Use a pipe cleaner to get in there or a garden hose with a spray nozzle. However there is one more crucial step not mentioned in the manual or in Solution #1. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver and gently pop it open. Under the panel is a small chamber where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place. This should fix your problem.
Dec 13, 2009 | Bosch Dryers
Hello, getting an error of F:03 on my WTE86300US Bosch Condensation Dryer. Do you know what the issue is?
Aug 06, 2008 | Dryers
Lint filter going off after 5 minutes then shutdown
Hello folks try this if you have not gotten this resolved. Your dryers have 2 sensor systems, the first one test the clothes for moisture, the second for the heat. The 1 sensor system drops resistance when the wet clothes are put in the dryer. the shutting down after 5 minutes and lint filter light coming on could be that the dryer isn't sensing the moisture. Now for the fun part, the entire inside of the drum and paddles is the moisture sensor. Try cleaning the inside of the drum with a cleaner to remove any detergent or fabric softner residue. This is crucial if you are using fabric softner sheets as they coat the drum. Also wash the lint filter with soap and water so the water goes straight thru instead of puddling up. Remember to also clean the condenser as this can trigger this issue as well. Hope this helps
Jan 02, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Asko T712C Dryer Logo
157 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you an Asko Dryer Expert? Answer questions, earn points and help others
