Question about Invacare Pronto M51 Power Wheelchair
How do I reprogram my invacare pronto m51power chair
I need to reprogram my invacare pronto m51 power chair. I need to increase the speed setting so I can use my power chair outside
    Scholar:
    New Friend:
  • 61 Answers
You will need to contact a service tech in your area to do this. They should have a special programmer box that can adjust the settings on the chair to improve the chairs performance.
Posted on May 08, 2015
dromtonpa
  • 40 Answers
SOURCE: oil / gel leak
If it is coming from your motors, it could be very bad. i.e. motor replacement. Sometimes on the side of those motors there is a black plastic cap about the size of a quarter or half dollar, those fall out sometimes and allow gearbox grease to come out. This should`nt be confused with your motor brush caps which are about the size of a pea and have a small **** in them for a screwdriver.DO NOT TAKE THESE OUT.  If the large cap has come out just stick it back in. If you can`t find it you`ll ned to call a dealer to get the part replaced.    If you can still find no prob,your probably going to have to go to a dealer.
Posted on Mar 26, 2009
  • 17 Answers
SOURCE: speed control knob has come off
you need Invacare part # 1040225, cost about $6.00. Call these people 866-722-4581
Posted on Sep 22, 2009
Testimonial: "I looked on the internet for this part for HOURS without success. The "FixYa" expert found the model number needed and the phone # to order. Thanks!! "
  • 11 Answers
SOURCE: where is the reset button on a invacare m51
The controller puts out fault codes though the LEDs. Count them and then look in the operators manual for likely causes. In my experience it is the electronic brakes that fail on these units and they are costly.
Posted on Oct 16, 2009
wcdoc1953
  • 280 Answers
SOURCE: i have invacare pronto m51 with surestep the spjis
The 9 flash error code indicates a communications fault. The communication fault relates to the communication between the joystick and the control module. The joystick on the arm mount is connected to the control module in the base. When there is a break in the wiring of this wiring harness, also called a bus cable, a fault occurs. This trips the computer and the computer sends out a flash code to the joystick. Simply stated there is a broken or pinched wire between the joystick and controller. Look physically at the wire and check for cuts, breaks or pinches. The best short term repair is to repair the broken wire with solder and heat shrink or tape. You can also use **** splice connectors and tape. The best long term repair is to replace the harness with a part available from Invacare. The most definitive way to diagnose this problem is to read the fault log of the controller using a hand held programmer available to dealers and certified technicians. The number and type of fault codes logged in the controller is another indicator of which
component(s) has failed. Hope this helps.
Posted on Nov 20, 2010
  • 692 Answers
SOURCE: i have an invacare pronto
Leet you have a left motor problem. Usually the motor has to be replaced Sorry Hope this helps
Posted on Mar 07, 2011
How do I reset m51 Prono power chair
There is no reset button on a M51. It only has fuses. If it is turning on and it has blinking lights or if you have a joystick that has a display that says Press Reset then the chair needs to have an external reset plugged into it or the chair may need to programmed or serviced.
May 20, 2014 | Invacare Pronto M51 Power Wheelchair
Reset button on pronto m51
There is no reset button on a M51 chair. Invacare puts fuses in the battery harnesses. The manual may say there is a reset but trust me there is not.
I have a pronto m51 wheel chair got the joy stick wet it flashes 7 times how can i fixs it
Here's your M51 manual:
http://www.invacare.com/doc_files/1125085J.pdf
Trouble codes start at p25.
Also, Invacare is proud of the M51's wet-weather performance (check the "Rain Test" chapter in the manual. You might have a warranty issue. Check with an Invacare dealer.
May 06, 2014 | Jet 3 Ultra Power Chair
Runs too slow.
max speed on most chairs is 5 mph if slower than that u may need to get the controller reprogramed by a tech,take into consideration also ok a wheelchair can be overprogramed in which case batterys wont last as long,or the motors will burn out be sure to tell him to reprogram to default settings only
Aug 31, 2013 | Invacare Pronto M51 Power Wheelchair
I have an invacare Pronto M51 Surestep power chair from 2008. I need the swing out foot rests in the red color. Can someone help me with this situation and what would they cost-thank you
If you have had swing away footrests on this chair you can replace them with model PHW93 and must ask to get them in red when you order them from a wheelchair store. If you dont know where a store is that sells Invacare products, call Invacare customer service at 800-333-6900.
Mar 08, 2011 | Invacare Pronto M51 Power Wheelchair
The wheels on my friends electrically powered Pronto 51chair are spinning on the carpet(which is not particularily worn). Are there any tricks short of new wheels that help remedy the situation?
Jet turn the speed down on the chair to try a slower speed it might help with the spinning and make sure the casters are turning freely and not creating a bind or excessive drag on the drive wheels. Good Luck Hope this helps you
Nov 15, 2010 | Invacare Supply Group Invacare Pronto M51...
Invacare pronto m51 moving very slow. moves free and easy when in neutral
Check that the speed control on your joystick is set to high. If it is then you probably have a battery problem. Even with all the lights lit on the joystick you can have one battery of the two on the chair that is not charging fully. This will cause the M51 to creep and not work correctly
Aug 11, 2010 | Invacare Supply Group Invacare Pronto M51...
Speed control knob has come off
Sep 21, 2009 | Invacare Pronto M51 Power Wheelchair
Invacare Pronto M51 Power Wheelchair Logo
721 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
