Question about Health & Beauty
Scooter starts but won't go into gear - Health & Beauty
I HAVE A CHINESE SCOOOTER THAT WONT START IT HAS NO BATTERY WILL IT WORK WITHOUT IT CAN IT BE KICK STARTED AND RUN WITHOUT NEEDING THE BATTERY
Hi, Montana and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Scooter Troubleshooting Scooter won start All about Scooters
Fix Chinese 49cc Scooter that won start
cranks but wont start
Scooter won start
http://scootdawg.proboards.com/thread/25213/engine-cranks-spark-start
Jan 09, 2017 | Motorcycles
How do I fix Jordan scooter that wont start
Hi, Anje and the usual suspects are:
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and downloads that you will need please visit the websites below. Good luck and have nice a day.Scooter Troubleshooting Scooter won start All about Scooters Scooter won start
http://www.sym-center.ru/files/jet-all.pdf
Jan 15, 2016 | Jordan Motorcycles
My sonic 3 wheel scooter will not go status light blinks 3 times the 1 time,3 times then 1 time ect, batteries fully charged unit is in gear what is wrong
Pride Mobility Products Corp. - Product Owners Manuals ...
www.pridemobility.com > Resource Center
Pride MobilityProduct Owners Manuals & Specification Sheets ... Jazzy Elite ES PortableSpecifications ... I 02/03. Jet 3 Ultra ... Travel Scooter Throttle Control Lever OperationProduct Insert .... Brochures · Owners Manuals · Basic Operating Instructions · BasicTroubleshooting Instructions · EMI / RFI Information · Warranty Information.
Sep 25, 2015 | Pride Sonic 3 Wheel Portable Scooter
Yamaha Fino scooter won`t start when egine hot. WHY???
Could be a variety of things. Vapor lock from a leaky carb. Carb running too rich. Engine overheated. Heck, could even be some weird wiring gremlin. Hard to tell for sure, but a good solid carb clean and reset should help either way...
Oct 02, 2014 | Yamaha Motorcycles
Yamaha Fino scooter won`t start after having been used and engine still hot. Have to wait min. 20 minutes restart is possibe. What`s wrong???
Hi, Anonymous you may have a faulty CDI box-pulse coil-exciter coil or ignition coil for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ZUMAFORUMS NET View topic Scooter won start when hot
scooter wont start when hot
http://www.49ccscoot.com/manuals/Yamaha_Vino_125_Service_Manual.pdf
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2008/vino125_lit-11626-21-54_1538.pdf
What is the main cause of un passing electric to start
Hi, Bijualexander and the usual suspects are:
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
50CC Scooter Wont start
How To Fix Scooter Starting Issues Part 1 Quick Guide
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
50cc scooter wont start need help
Scooter won start
Apr 26, 2014 | Bajaj Motorcycles
Vespa engine won't start
Hi, Anonymous and the usual suspects are:
http://modernvespa.com/forum/wiki--won-t-start-diagnosis-for-beginners
Scooter won start
Vespa 300 GTS Starting Problem
When the Vespa Won Start Scooter in the Sticks
Jan 14, 2014 | Vespa Motorcycles
Won.t start after replacing belt
CHECK BELT AND SEALS ETC ADD GEAR OIL
Apr 17, 2013 | Motorcycles
Baja sc50-2 scooter
Hi, Benny and the usual suspects are:
Startup Troubleshooting Starting Your Scooter 1 7
Scooter won start
Baja Panterra 50 90cc PDF Service Manual Downloads on 4Strokes com Forums
http://www.bajamotorsports.com/system/documents/63_OWNERS_MANUAL_-_SC50_-_Sun_City_50cc_Scooter_Owners_Manual_VIN_prefix_LAWA_.pdf
Feb 13, 2012 | Bajaj Caliber 115 Motorcycles
Starter motor just whines and wont start
Hi, Rayanthony19 the starter drive/Bendix is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day. Archived Scooter Startup Questions Won Start at All http://www.apriliaforum.com/forums/showthread.php?280275-2003-Derbi-GPR50-Starter-Motor-issues
http://www.49ccscoot.com/manuals/Derbi_Scooter_Manual.pdf
https://www.oemmotorparts.com/oem2.asp?M=Derbi
Feb 22, 2011 | Derbi Cross city Motorcycles
Health & Beauty Logo
67 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
