I have an idylis 12000 btu model 146710 air unit. It will start cold then stop and the temp goes up . do you know what causing it
    Master:
  • 495 Answers
The condensor (outdoor radiator) needs free airflow thru it. clean it with garden hose water. Is the temperature setting down cool?
Posted on May 02, 2015
    Top Expert:
  • Heating & Co... Master
  • 50,533 Answers
The compressor stops working
check the timer setting and turn it off . if that fails get a technician to check it out as it may be the outside power board.
  • 3422 Answers
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
Posted on Jun 22, 2008
SOURCE: Kenmore 18,000 btu Air Conditioner model # 75180 - Condensor Problem
HI , LISTEN MY AIR CONDITIONER DOES NOT START. CORD,THE POWER-TEMP CARD OR WHAT ELSE IT HAPPENED IN A LIGHT OUTIGE. THANKYOU. IT A KENMORE 18,000
Posted on Oct 20, 2008
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
  • 659 Answers
SOURCE: Sometimes it blows cold, sometimes it doesnt.
The coils that are located right behind the filter need to be cleaned extremely well. You can purchase a spray from your local hardware dealer that can clean the coils. Also, rinse the fins at the back side of the unit as well. Dirty units can cause this to happen. If you clean it and it continues, you have developed a refrigerant leak. Since window units are so inexpensive today, it is not cost effective to hire someone to come out and find and repair it. Hope this is of help to you.
Posted on Apr 11, 2009
SOURCE: 9000 btu maytag portable AIR CONDITIONNER Model M6PO9D2B-B
Reasonalbe rule of thumb is a difference of 10 degrees Centigrade.
Charlie
Posted on Aug 18, 2009
RE: IDYLIS Model #0625616 Portable Air Conditioner - what are the BTUs for this model? Thank you
Just get the tonnage and multiply by 12000 .That will give you your BTU
Jun 03, 2017 | Heating & Cooling
Do you have a user manual for an idylis air purifier model IAP-10-200?
Idylis IAP-10-280 C & D Filter Change for Part # IAF-H-200C ...
? 2:16
www.youtube.com/watch?v=rZApdO6gSM4
Apr 16, 2014 - Uploaded by Crucial Air
http://www.crucialair.com Replacing your Idylis IAP-10-280 C & D ... As the air filter accumulates more debris over time, the air purifier's filtration capacity lessens. ... Lowe's Idylis 10,000 BTU A/C Instructions (Model: 0146709)
Sep 17, 2015 | Air Air Purifiers
How to know the tons of old ac unit from the model no?
36 is equal to 36000 btu. To find the ton divide by 12000 btu. 12000 BTU is a ton of refrigeration. This is a 3 ton unit.
Jun 17, 2014 | Weather King 10AJA6001AH Air Conditioner
Idylis 12000 btu manual
Find more information on this link:
http://pdf.lowes.com/useandcareguides/840206110031_use.pdf
Jul 13, 2013 | Heating & Cooling
What extension cord should i use on window ac unit model number ASW12ALS1 12000 btu
http://www.appliancefactoryparts.com/search/part/1042383/116404 this is a link formthe extension cord you need.
Jun 20, 2012 | GE 12000 Btu Room Air Conditioner EnerStar...
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
I have a 12000 btu samsung ac. it starts and then
As long as you are sure the thermostat is qired corectly, The unit may be trying to start sgainst high head pressure, have a b bad start relay or start capacitor. Reck your connectiond and make sure the thermostat is push all the way into its pin sockets.. Good luc
Sep 19, 2009 | Heating & Cooling
Mr slim unit in bedroom 9kbtu - room 11x12'- is humid, awful
Lets clarify. DRY mode only dehumidifes that air and does not cool. Cool is used for cooling. Dry mode doesn't normally have temp control; it is automatically set by the unit. I think 9000btu is a big unit for the room; it is overkill. I would switch to a 5000btu unit. it cannot be fixed and the BR unit needs to be uninstalled and the new unit needs to be re-installed. The price of commisioning, de-commisioning and new unit is something in which you will have to pay.
I take the time to answer your questions, so please rate me.
Thankyou
Mat
Aug 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
