Question about Exercise & Fitness
What does it means error code 4 for Stex 8020Tx treadmill
  • SID BOSS
    SID BOSS May 03, 2015
    Does error 4 code mean communication failure or motherboard failure?
    Master:
  • 680 Answers
Sounds like a component broken.
Terry
Posted on May 02, 2015
I need a manual for stex 8020t treadmill
Unfortunately no manual is available online but if you contact http://www. synergyfitness. com.au/ they should be able to help you
Aug 16, 2013 | NRS Stex 8020T Treadmill
Stex treadmill about error 2
adjust the Speed sensor, see the diagram, clean it, test for open or faulty, and tight the connector very well.
Lube the deck belt, see the video, lube the rollers bearing front+back too , test the drive belt motor and replace the belt if necessary. God bless you
However you must try to Run the software calibration after your fix it.4d80cf2e-89d9-4476-902b-88e5991886e8.gif
Jul 03, 2013 | NRS Stex 8020T Treadmill
Error code 1
I am the same Problem with Stex 8020 T Error Code 1
Oct 25, 2010 | NRS Stex 8020T Treadmill
Treadmill Stex 8020 when switched on immediately increases speed on board (without touching buttons) until it reaches 250km...the belt isn't moving when this is happening and pressing + or - or other...
If it reaches 250km then I suspect that the upper electronics is not functioning properly contact the distributor of Stex and If under warranty they sould cover it,but send out a servicer
May 03, 2010 | NRS Stex 8020T Treadmill
Belt is slipping, even on the lowest power.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
As far as the manual, I have not been able to found it anywhere yet.
Jan 22, 2009 | NRS Stex 8025TL Attachable 17 Inch Lcd Tv...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
