Question about Refrigerators
I bought a kic kombi fridge a week ago,and it shuts off nd runn again by itself,is that normal? And also when running it makes nose like it is drawing gas or something,please assist with advice. -max
  • Refrigerators Master
  • 5,323 Answers
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
I bought a kic kombi  fridge a week ago,and it shu - 25675828-izj50bzy441rirqhwblyybfs-3-0.jpg
25675828-izj50bzy441rirqhwblyybfs-3-2.png I bought a kic kombi fridge a week ago,and it shu - 25675828-izj50bzy441rirqhwblyybfs-3-9.jpgt/uploads/images/25675828-izj50bzy441rirqhwblyybfs-3-9.jpg" alt="25675828-I bought a kic kombi fridge a week ago,and it shu - 25675828-izj50bzy441rirqhwblyybfs-3-14.jpg_mi" />
Posted on May 12, 2015
dididsaythat
  • 291 Answers
SOURCE: Fridge Problems
what model and make is it
Posted on Oct 31, 2007
Bgillespie
  • 89 Answers
SOURCE: 64194 Daily LOUD running noise
Unplug, and take cardboard cover at bottom off using 1/4 nut diver. Look at the fan; is there anything touching it? Spin it with your finger. Wait a few minutes then plug back in. Is it comming from the roundish black thing the size of a basketball? If so its not worth fixing?GOODLUCK>>>
Posted on Dec 17, 2007
peyton32034
  • 410 Answers
SOURCE: KIC 223l fridge - what length time reqd to let gas settle?
if it was transported upright you should be able to plug it up right away and allow it to start cooling peyton..
Posted on Jan 28, 2009
SOURCE: sub zero fridge model 561 not making ice
Thanks to everyone for the help.We did get it moving and working finally. My husband took the ice drawer out. Reached up to where the ice drops out and poked around a bit. He said he didn't move anything but I heard a piece of ice move. We then shut the power off at the breaker switch, waited 10 seconds or so then turned back on. An hour or so later, we heard ice drop and it's still making ice. What a relief. I
could tell there had been a power failure as the clocks all needed resetting. So as someone suggested, we just had to reboot the thing.
We tried everything after reading 50 plus pages of questions and answers and finally got it. Thanks so much!
Posted on Jan 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: Fridge running continuously
Another defective thermostat.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jan 13, 2010
Fridge not cooling as well as it did until recently.? It normally operates ok at 2-3 but now cooling poorly at 4 and upwards
Youve got more food in it so it needs more energy.
the doors are not sealing shut make sure its sealing properly .
Is it old ,, when you say normally do you mean 2-3 weeks ago or 2-3 years ago .
have you checked the manual for troubleshooting
have you contacted the manufacturers customer support
Nov 15, 2016 | Refrigerators
Reduced engine power warning light
Did you get the codes before you cleared the memory? The codes play an enormous part in diagnosis. If you did not copy the codes befored you cleared them make sure if it happens again that you do.
Mar 22, 2014 | 2004 Pontiac Grand Prix
I bought a new kic fridge with freezer about seven months ago. I have been using it ever since. However my electricity has recently been cut and I will be without electrity for the next 10 months. Can this...
It'll be fine. Leave the door ajar and clean it inside with bactericidal cleaner after you finish using it and before you start using it again.
May 09, 2012 | Freezers
I bought the fridge in 2006. In 2008 it began making a loud vibrating noise. Repairman replaced the fan motor blade.Took 30 days to get part! It was never quite right after that. Had problems with defrost...
Could all be in the fan motor. If it's bad again, I would change the motor and blade. Then fire it back up and test for correct cycling.
That may take a week of running until you get a true picture of whats happening, but they do have a lot of trouble with the motherboard./
Jan 17, 2010 | GE Refrigerators
99' Durango 5.2L - Wont Idle
TRY DOING A RELEARN AGAIN IF OCCURS AGAIN PCM IS LOSING ITS LEARNED MEMORY POSSIBLE PCM MALFUNCTION OR STUCK IAC
Mar 29, 2009 | 1999 Dodge Durango
Jan 28, 2009 | Refrigerators
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Fridge Problems
Oct 30, 2007 | Refrigerators
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
