Question about Nostalgia Electrics CCP-600 Movie Time 59 Inch Popcorn Cart
I need to find part that attaches electric plug to kettle,
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
Oct 15, 2015 | Oster 1.7 L Variable Temperature Electric...
Information to question already asked the fact the power is lighting both lights up but no noise of starting to boil does this kettle need a new element and if so where can a get it fixed.
You are not specifying what make it is but you hardly get replacement elements for kettles any more. The fact that you can see that power is available at the kettle it is indicating that it might be the element being defective. Had it been it switched on without any water in it? If it is the old type where the electrical cord gets plug in at the kettle check if it is well plugged in otherwise it is time for a new kettle.
Apr 09, 2015 | Kitchen Appliances - Others
Fuse box turned off when switch on the kettle
kettle defected check for short or to many plugs on servie line try another plug
Sep 02, 2012 | Russell Hobbs Kitchen Appliances - Others
How to clean my Braun electric kettle
Hi, follow the instruction below to clean it up...
Unplug the tea kettle from the wall outlet, and detach the plug from the kettle.
Pour 1/4 cup white vinegar into the kettle, and fill the kettle halfway with hot water.
Agitate the kettle so the vinegar mixture hits the sides of the kettle walls, and let the water sit for 20 minutes.
Discard the vinegar water, and scrub the interior of the kettle gently with a nylon sponge.
Rinse the kettle with hot water, and repeat as needed until all buildup is removed. Let the kettle air-dry before inserting the cord back into the kettle.
Apr 17, 2011 | Braun WK200 Cordless Electric Kettle
Flash from beneath kettle. Now not working. It is not the fuse in the plug
get it serviced the think is the heating coil may have got burnt out if you need to replace it remove the cover below and take out the coil carefully with the terminals replace the coil of same wattage usually 700watts in the same way
there can also be a problem with some wire got burnt due to heating .try to find the wire located near/attached with the heating coil and check whether everything is correct
Dec 04, 2010 | Alessi MG32 Cordless Electric Kettle
I have the Helman Nostalgia Electric Retro kettle popcorn maker and i lost the instructions manual i would like to know the amounts of corn i have to put and if i need to use oil or butter to prepare the...
Here is a link to Nostalgia Electrics..Fill in their form and you can go from there. Here is the link... copy and paste it into your browser or try to click on it..Hope this helps you..Wayne
Jan 25, 2010 | Helman Group RKP-630 Popcorn Maker
Female Old Fashioned Movie Time Popcorn Machine part of under-ket
You need a new kettle. Call Nostalgia Products at 920-347-9122.
Jul 26, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
I need directions for the TFal Vitesse cordless electric kettle. 7845162 Thanks
Fill with clean water to fill line. Have base plugged in. Place kettle on base and press down button on top of handle. Water should boil quickly and turn off automatically when done.
Mar 09, 2009 | Tefal 78451 Vitesse Cordless Electric...
Nostalgia Electrics CCP-600 Movie Time 59 Inch Popcorn Cart Logo
429 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Wayne Fellows
Wayne Fellows
Shehu Pro
Shehu Pro
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
