Question about Maytag Dishwashers
How do I open the door of the maytag dishwasher MDB4949SDH model. The screen says clean but the door won't open
Maytag dishwasher MDB4949SDH. The door will not open after the cleaning cycle has finished. The screen says clean but it won't let me open the door.
  • 152 Answers
That's kinda odd but try turning off the power to it. Then try to open door. If it still won't open then put power back on and try again. Sometimes computers get confused.
Posted on May 02, 2015
When I push auto and start the lights go on and the time, but then it goes off. Why?
Hello. Is this unit less than 1 year old? If so, anything defective is covered under the warranty(parts and labor). After 1 year, certain parts are covered, however, no labor is covered. Make absolutely sure the door is closed properly--there is an internal door switch that must be closed(tells the main board it's okay to start the cycle) or nothing will happen and produce the exact symptom you describe. Next, the unit could be experiencing an error condition causing the shutdown. Make sure the water supply to the dishwasher is turned on(and always run the hot water in the sink before starting the dishwasher to ensure hot water gets to the unit). Next, do you hear the drain pump working? A lot of dishwashers turn on the drain pump immediately to remove any standing water in the pump before letting in fresh hot water. If the drain pump is jammed or clogged, you might hear a soft humming sound only(from the motor trying to spin) and then the dishwasher will shut down due to it detecting a malfunction. Check the float switch in the tub to make sure nothing has gotten underneath it(ex. a spoon or fork can become lodged underneath and the dishwasher thinks there is already water inside and won't fill) I hope this helps you!
Oct 12, 2015 | Maytag MDB4949SDH MDB4949SDH Dishwasher...
Maytag dishwasher Model MDB7749AWB won't start/respond
Either the start switch, the start relay, the wires between them, the wires to the motor, or an internal fuse inside the panel, or the door safety interlock could be the problem. Even, any combination of the above could cause this. This is a real troubleshooting problem. Are you game?
Dec 28, 2012 | Dishwashers
Dishwasher door won't unlock
replace the electronic door lock
Aug 12, 2012 | Maytag Dishwashers
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
Have a brand new maytag dishwasher. When the cycle is finished the clean light stays on and I have to push buttons to clear is this normal?
If you open the door after the cycle, does it clear the display? Mine is a different maytag model, and when it's done it shows the display as clean. The display will go blank when I open the door manually... let me know if that helps.
KEN
May 10, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Soap door won't open
One or both of your spray bars are not turning, and are either clogged with stuff, or the pump is failed, or the inlet screen to the pump is clogged, or the pump impeller is clogged or broken.
Take the spray bars off and make sure the insides are clean and the nozzles are clear.
If you hear water spraying around the dishwasher, then chances are the other problems I mentioned are not a problem.
Let me know what you find and I can give you more help.
Feb 01, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher detergent door won't release soap
There's an answer at: http://www.partselect.com/dishwasher+cup-wont-open+repair.htm.
Pretty in depth, but not a simple fix.
May 22, 2008 | Maytag PDB3600A Built-in Dishwasher
Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Mar 11, 2008 | Dishwashers
Dishwashers Logo
227 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
