Question about Jabra Radio Communications
I need to unpair Jabra Wave+ from another device. Then pair to my device. ZTE Max
SOURCE: JABRA BT250V Hearing Problem
Cannot get my Jabra BT 250v to work with my Blackberry Curve 8310. Phone indicates I am paired, but there is no audio through earpiece. You can still hear audio through phone. Help.
Posted on Jul 22, 2008
SOURCE: Cannot pair a7010 with Plantronics Voyager 520
The actual problem was Plantronics, I was not turning on pairing mode. I was confused with quick pair which starts not immediately after turning on, but you need to hold the button longer until led will start blinking blue and red.
Posted on Aug 23, 2008
  • 5 Answers
SOURCE: Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Posted on Jun 29, 2009
  • 4 Answers
SOURCE: i cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Posted on Sep 10, 2009
  • 123 Answers
SOURCE: its not pairing, i previously
To reset the Z9i to factory settings; while in idle mode (not
connected to any device), Click Volume , Volume and MFB together (3 buttons). The Z9i will refresh its
memory, delete all current pairing information and automatically go into Pairing mode (LED will fl ash Blue) ready to pair
with a new device.
Posted on Aug 18, 2010
Can't pair ZTE N9120 with zabra
CHECK THE BLUETOOTH CONNECTIVITY VERSION OF YOUR HEADSET AND YOUR CELLPHONE
Dec 26, 2013 | Jabra Radio Communications
Cz302 'pair full' problem. My Clarion CZ302 car
I had exactly the same problem. No clue at the beginning. Then I find out the quite trivial solution. The radio had been pairing with the maximum number of devices (three I think) and so it doesn't accept any other device. First you need to "un-pair" an old device and then pair the new one. In order to unpair devices you need to go in the settings, then in the "delete pairing" and remove the device you want to unpair. The manual of the radio explains how to go in the settings.
In conclusion, no particular trick is required: after unpairing the old device(s), the pairing with the new one is immediate.
Sep 08, 2013 | Clarion Car Audio & Video
Atrix will not pair with java wave after update
Hi are you ensuring your Jabra Wave is in pairing mode when you search on your Atrix?
Nov 13, 2012 | Motorola Mobility Atrix Certificate...
I just bought a new phone and want to use my old bluetooth,Do I unpair it from my old phone So I can pair it with my new phone?
You don't need to unpair it. Turn off the headset. Hold the power/call button to make it discoverable. Add it from your new phone. It usually uses pin 0000 or 1234.
Jun 13, 2011 | Jabra VBT185Z Bluetooth Headset
Cannot get my phone to recognize the device. need steps 1,2,3
Here is the link pages 4and5 (http://img9.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2070/BT2080_UM_6909.pdf)
Feb 12, 2011 | Jabra BT2080 Bluetooth Headset
Cant pair my bluetooth
The default code is 0000 for most bluetooth devices. If that doesn't work try 1234.
Sep 12, 2009 | LG Wave AX380 Cellular Phone
The phone says that no dvice can be found
it will be like the headset is paired with another phone previously. so you need to unpair that first.
turn on, turn off and turn on while holding the ON button along with the volume up button. it will blink and when the light will show up continuously, the unpairing is complete.
now search for the bluetooth from mobile and pair. i guess you know the password. ...... the default pasword for all headstes will be 0000 which you have to input from mobile when prompted
Aug 14, 2009 | Jabra Bluetooth Headset with Adjustable...
I was paired to one phone, now I need to "unpair" because that's what Verizon told me to do, the phone pairs, but won't connect.
No such thing as unpairing, remember that not all bluetooth devices are compatible. A complete list of phones that are compatible are located on motorola's website, under consumer products, bluetooth. BTW, if you don't know the pin to pair the devices is 0000
Jul 31, 2009 | Motorola Mobility Bluetooth Car Charger...
Cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Dec 07, 2008 | Jabra BT150 Wireless Headset
Jabra 250 Codes
To make this complete: You need to turn off the headset (hold call button several seconds until it makes descending tone). Then hold button to turn on and keep holding 8 seconds more until blue light is on solid. Then initiate pairing at phone, and enter 0000 as the code.
Mar 24, 2008 | Jabra BT250 Consumer Headset
Radio Communications Logo
42 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
