How many DC volts are needed to work my speakers?
    Top Expert:
  • 10,875 Answers
6 volts
Posted on May 02, 2015
2 Suggested Answers
SOURCE: need to no the dc volts to run fps 9634 speakers
10V 1.2A. -ve polarity on outer connector
Posted on May 02, 2009
How volt transformer for AOpen spekers?
If it is the transformer, it should be a DC output. Look where it connects, it will tell you what voltage you need. Use a volt meter to see if you are getting that from your "transformer". If so the amp in the speaker is probably blown, if not you need a new DC power supply with the correct voltage. If the replacement ma is higher that will not hurt, The information should also be on the "transformer".
May 31, 2016 | AOpen Audio Players & Recorders
I have Cintre desktop speakers but no power supply. Where can I get one?
first off need to know specs what voltage it uses ac or dc
amp draw and volts should be market on speakers then you need to no if dc volts what part is negative and positive on terminal connection send model #
Feb 27, 2015 | Audio Players & Recorders
My dc691p speakers require 9 vold dc. Will it do any harm to use a 19 volt dc
yes, your speakers will be damaged. do not connect 19 volts to a 9 volt device. go to walmart or radioshack and purchase the correct power supply.
Mar 01, 2014 | Juster AC-691 Computer Speakers
How many volts is the power adapter
The speakers use a 10 Watt power supply
Sep 06, 2011 | Sony SRS-A37 Computer Speakers
Hello everyone! I have lost my Koss HD50 power supply and was wondering again, how many volts and how many amps? ex:6V, 500ma Thank you kindly! Erjel
Three C cell size batteries per speaker is what you use if you are on the go.
http://www.shopping.com/Koss-HD-50/the-paradox-decent-small-computer-speakers/1386310/reviews#tabAnchor
Hmmm.
EACH C cell battery produces 1.5 Volts (DC)
3 times 1.5 Volts (DC) = 4.5 Volts
Total of 9 Volts (DC)
500 MilliAmps?
Your main concern is with the Voltage.
The Amperage can vary. It can be more than needed.
Why?
Because Amperage represents Current.
How much Current is available.
(Water hose example;
Voltage is the speed, or velocity of the water coming out. Amperage is how many gallons per minute that comes out of the hose)
However, you better make sure that EACH speaker receives No more than 4.5 Volts (DC)
Since you do not have the special splitter adapter cord that comes with the power brick, you will have ensure that EACH speaker receives no more than 4.5 volts.
This is if you are trying to use a 9 Volt (DC) power supply. (AC adapter)
Please post additional questions in a Comment.
Regards,
joecoolvette
May 30, 2011 | Koss HD 50 Computer Speakers
What voltage are the koss 'older' computer/CD speakers that would take 3 'C' batteries each. I have a variable voltage adapter and am not sure if I should switch it to 9 volt or another setting for AC...
C cells are 1.5 volts each. If the speakers use three of them that means you'll need a 4.5 volt supply. If each speaker needs batteries, you'll need to feed that voltage to each speaker, and the supply should have enough current for the total load. A 1-amp rating is probably fine.
Dec 24, 2010 | Koss HD 50 Computer Speakers
What voltage and polarity do the ACS-5 speakers require?
Computers always use DC voltage. Computer speakers receive DC voltage from the computer.
DC voltage has a Positive and Negative polarity.
In the power jack of the speaker, the Center pin is the Positive connection. The outer shell is the Negative connection.
Center hole of the DC adapter plug - Positive.
Outer shell of the DC adapter plug - Negative
Voltage 5 Volts DC.
In case you need it,
http://support.dell.com/support/edocs/dta/acs5/
Nov 29, 2010 | Computers & Internet
I have Yamaha psr 260 and I am connect on 24V, and now speakers dont work. What am I doing?
I believe that is the wrong VOLTAGE !!!
The PSR takes a 12 volt, 1 amp or more DC power supply with positive on the pin.
If you have connected 24 volts either AC or DC of either polarity you have likely caused internal damage. Try a 12 volt DC supply and if it doesn't work, it needs to go to a repair facility.
ALWAYS check the voltage and the polarity on ANY of the devices using the power adapters BEFORE connecting the adapter..
Feb 18, 2010 | Yamaha Music
What kind of external power supply does the media speaker needs?
Juster-Avia 3D-107 Media speakers.
I wanted to know what kind of external power supply it needed. I open the case and saw 4 diodes which tells me is a bridge rectifier circuit. I also looked at the filter cap and saw ????uF at 28 volts. Therefor, I did the Scientific Wild *** Guess( A.K.A. SWAG METHOD)
12 volts AC out at 1.6 amps or higher.
Apr 28, 2009 | Juster 3D-102 Computer Speakers
108 people viewed this question
 Grubhead
Grubhead
