How do i hook up my dvd i have 3 connect plug
    Top Expert:
  • 10,875 Answers
Red is rt sp white is lft sp yellow is video
Posted on May 02, 2015
How to hook up my dvd player
if you want to hooked up your dvd player to a tv unit, you can use an rca connector. usually 3 wires for video and L/R audio. to connect with in the tv plug one end of the connector to the component input jack of the tv ( video/audio L/R ). and the other end of the connector just plug to the video/audio output jack of the dvd player.
Sep 17, 2012 | Televison & Video
How to connect all components to work
you will have all them all in user manual itself right?
Jun 08, 2008 | Audio Players & Recorders
Ihave a bose 321gsx, I want to hook up my hdtv . ,blue ray dvd and vcr. Brain is frozen right now. Could use some help.
How to Connect an HDTV to a DVD Player
Hooking up a DVD player to an HDTV, or high-definition TV, is just as simple as hooking one up to a standard-definition TV. While a regular DVD player may be hooked up to an HDTV, it does not necessarily mean it will have high-definition quality picture. Unless a Blu-Ray player is connected to the HDTV, only a standard-definition picture will be shown.
Things You'll Need:
* Component cables
Instructions
Turn off and unplug the HDTV set and the DVD player before attempting to connect component cables to them.
Match the red, green and blue colored cables to each of the color-coded counterparts on the back of the DVD player. Be sure the cables are being plugged into the TV-out section of the DVD player.
Plug the other end of the color coded cables into the HDTV set. There should only be a red, green and blue cable being plugged into the TV. It does not matter what input these cables are plugged in, but keep track of which particular one it is. Most HDTV sets will have more than one A/V input, which is why it's important to take note of where the component cables are located.
Power on the DVD player and the HDTV set. If not already plugged in, ensure both of these are properly plugged into an outlet.
Press the "Source" button using the HDTV remote and locate the input channel that has the component cables plugged into it. The HDTV set should now show the DVD player logo or an introduction to the DVD.
Do not purchase HDTV component cables to hook up a regular DVD player to an HDTV set. Unless using a Blu-Ray player, only standard component cables are required. HDTV sets consume a lot of energy and should be plugged directly into an electrical outlet rather than a power strip.
Turn off all electronics before connecting and disconnecting wires to reduce the chances of getting an electrical shock.
Ensure that you have the proper cables to hook up your new HDTV. Take inventory to see if you have an ANT-IN, DVI-D/HDCP IN, Video In or Component Video In cables. The placement of these plugs will be indicated in your user book.
Begin by connecting the coaxial cable to the back of your cable box. Run a video cable to the TV; an S-Video cable may be used as well if you do not have any other video cables.
Locate a digital audio cable, or analog audio cable. Connect the audio cable to the TV from the cable box.
Now connect all other components including DVDs, VCRs or LaserDISC players. Try using all digital audio and digital video connections for the most complete HDTV experience.
Use a splitter to connect multiple components such as cable box to DVD or TV to VCR to avoid running out of chords. Calibrate your HDTV before enjoying fully, adjust the brightness, contrast and color settings.
Tips & Warnings
You can utilize a program to help with proper calibration of your HDTV system; these instructional videos can be purchased from many electronic stores.
You can opt for the store from which you purchased your HDTV to hook up the system for you. They will often calibrate the system for you as well.
Hope it helped.
Have a nice day...
Feb 26, 2011 | Bose 3 2 1 GSX System
I have an older TV with only an antenna hook-up, a VCR, a DVD recorder and a converter box that I would like to hook all together. I can get the VCR to work, but don't really know how to hook the DVD...
Try this. You will need 2 RF cables and a RCA cable that has a red, black, and yellow plug on each end.
  1. Plug the antenna signal into the converter box.
  2. Connect the RF output (TV out) of the converter box to the RF input on the VCR
  3. Connect the RF output (TV out) on the VCR to the TV
  4. Finally, plug the DVD recorder into the converter box also, but use the 3 RCA cables that came with it (audio left, right and video).
Apr 13, 2010 | iLO DVDR05 DVD Recorder
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
Hooking my DVD player up to my HD converter
connect as follows,,,
converter-->VCR-->TV
DVD-->VCR-->TV
watch DVD as before, when VCR is off, the converter will show up on the TV
Feb 19, 2009 | Televison & Video
Have a Sanyo DP42828(42"). My Satellite is working after the card resetting itself. But which 3 holes do I hook the (RED, YELLOW, and WHITE) for the dvd player?
dems,
Are you reffering to your DVD player to be conected to with your TV screen?
For DVD player connection the 3 colored RCA jack socket are:
YELLOW = video out
RED and WHITE = Audio out (left and right channels)
to hook up to your screen, at the back of the screen or side of it you'll see RCA socket indicating "AV1" "AV2" AV3" this are all Audio/video inputs where you can hook up all you A/V device or game consoles. These inputs also have the same 3 colored socket (yello = video red/white = audio)
connect your DVD player to any of this input following the same color code.After connecting the cable, select the input where you hook up your dvd player. Do this by pressing "A/V" buttons in remote commander of your TV. continously press this button until it reaches the exact location where you plug your player ex. AV1, AV2,AV3
note: in some cases the remote commander doesn't indicate this A/V button but a picture of a box having a arrow pointing inside the box.
cheers,
mark
Jan 05, 2009 | Sanyo DS31590 31" TV
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
DVD VHS Recorder setup.
hi there, a little late.....but here we go........do you have cable? if yes connect the cable from the cable box out to dvd in and connect the dvd out to tv in.......pls note the dvd and tv must be set/tune to ch #3.(and you cannot record HBO)......you dont have cable just tv and dvd you need rca wire (red,white & yellow) also the F connector wire....in back of dvd connect the 3 wires audio in video in (is your tv/monitor a flat panal these connections might be on the side) if not its in the back plug in to out on tv....(this is so you can record)....plug the F conncetor wire from dvd to tv......on this connection you can set the dvd to ch #3 or any ch you want to record...........
Jul 19, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Connecting VCR/DVD combo to TV
If that is the only input that the tv has it's still usable. Just plug the Cable TV or antenna cable into the DVD/VCR coaxial input labeled "in" (instead of the TV's) and hook one from the DVD/VCR's "out" to the "in" on the tv. Turn the TV to channel 3 or 4 (depends on DVD/VCR settings) and use the built in TV tuner on the DVD/VCR to change channels.
Sep 20, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
