Question about Soundcraft GB4 Series 24-Channel Live Production Console
Soundcraft gb4 will not power on
It just wont turn on. I have checked the fuse, power cable everything that I can think of without a service manual. Does anybody have a suggestion?
AMPLIFIER CUTTING OUT WHEN SOUNDCRAFT EFX8 GOES INTO HIGH LEVELS
Hi Terence!
Check your Amp Frequency Ratings and also your power supply.
Increase the high levels gradually until cut-off.
Try reducing your output level at the EQ to match the Input Level at the AMP. What Brand & Model Amp is it plugged into?
Here is a link to EQ manual of operation.
Good Luck,
JP
SoundCraft EFX8 Manuals
Oct 14, 2015 | Soundcraft Music
Not working
check the power line cable, make sure the correct voltage is supplied,
Apr 13, 2014 | Soundcraft GB4 Series 24-Channel Live...
I need number ic power supply mixer soundcraft efx16
you are looking for a Soundcraft HB0166
Power Supply check it out here...
Soundcraft HB0166 Power Supply FX16 Full Compass
Jan 19, 2014 | Soundcraft Music
Souncraft GB4 ch 16 Right mix chanal dead
If you aren't using one of the group outs you could re-route the main L/R through one of them. I can't remember if that board will let you configure the MONITOR outs for either PRE/POST fader but if so you could go that route too.
Otherwise that fader is most likely dead & you'll probably have to replace the MAIN L/R, master output module if you can't find a competent tech to fix just the fader.
Feb 14, 2013 | Soundcraft GB4 16 Mixing Console
My 97 honda passport has no electrical power and wont turn over or run. checked battery, cables, and fuses. someone advised may be related to a fuel pump issue. what do you think
you would want to check the ignition switch since this is the area that everything goes through all your power for everything in the car goes through it, its in the column and should have visible or audible signs of wear if that is it
Mar 07, 2011 | 1997 Honda Passport
Please help. Cannot turn the soundcraft gigrac 600 on.
Check the fuse. If it has blown, do NOT replace it without taking for service first. Additional damage often occurs when users replace fuses that have blown due to internal failures in equipment.
Also check that the power cord is fully seated... sometimes they don't quite make it...
Feb 04, 2011 | Soundcraft Gigrac 600 Powered Mixer
What does the "EQ" button do?
Its as simple as it looks. Th eq butom activates the EQ control. Turning it off bypasses the EQ which is helpful for comparative listening. A lot of destruction can be done with improper equing so sometimes its a good idea to just turn it off and evaluate what the recording originally sounds like with out being tampered with. Some units have a tuneable frequency selection so you can digitally hone in on the desired frequency range that you want to bump or reduce but those are labeled frequency more often than not.
Dec 29, 2010 | Soundcraft GB4 32 Channel Dual-Purpose...
Soundcraft GB4 Series 24-Channel Live Production Console Logo
226 people viewed this question
Top Soundcraft Audio Players & Recorders Experts
shaqsatin
Level 1 Expert
Gil Shultz
Jerry Kramer
Jerry Kramer
Are you a Soundcraft Audio Player and Recorder Expert? Answer questions, earn points and help others
