Question about EEEKit Portable Office 4-in-1 Kit for 8 Inch Tablet Winbook Tw801 Tw802 ASUS VivoTab 8 M81C-B1-BK HP Stream 8 32GB Windows 8.1 Nextbook 8 Windows 8.1 Samsung Galaxy Tab 3/4 Note Pro 8.0 Le Pan Mini 8 TC802A Verizon Ellipsis 8
Need help with key board - EEEKit Portable Office 4-in-1 Kit for 8 Inch Tablet Winbook Tw801 Tw802 ASUS VivoTab 8 M81C-B1-BK HP Stream 8 32GB Windows 8.1 Nextbook 8 Windows 8.1 Samsung Galaxy Tab 3/4 Note Pro 8.0 Le Pan Mini 8 TC802A Verizon Ellipsis 8
  • EEEKit Master
  • 5,631 Answers
If you are using a bluetooth keyboard, you shoud turn it on, turn your tables, go to setting, enable bluetooth and get it pair with keyboard.
If any other question, be specifi about help you need
Watch video hor to pair tsblet with keyboard
Bluetooth Keyboard Pairing Windows 8 Samsung Series 7 Slate Tablet
Posted on May 12, 2015
My at symbol and others do not work. how can I fix this please?
Catherine, Try compressed air to blow dust and debris from key board, try a system restore to an earlier date, you could also try re installing key board/driver, you may also have faulty key board and need to replace..
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Some Keyboard Keys not working
Not all keys on keyboard work
Some of my keyboard keys aren working
Aug 07, 2016 | Logitech Computers & Internet
I have a problem with my laptop key board , some of the keys are not working so my question is i have to change my whole key board or the keys only which are not working?
I would think you would have to replace the key board, if u have a fair idea of what your doing u can do this yourself. youll need the computer model and search for one on the net, then once you have it youll have to take the screws out of the computer(don't unscrew the lcd screen bolts)their also maybe some screws underneath the keys as well, ujust have to lift them from the bottom upwards and they should pop off and on.Hope this helps you.
Apr 05, 2013 | Computers & Internet
My sanyo model #dp37649 turn on and off over ond over done replace main and power boards what do i need to do to fix it
Hey Chris, take off the back cover of the set and disconnect the key controller board. The key controller is the board that has your side buttons attached to it. If you replaced the main board and power supply with good parts, the only logical thing to try next is the key controller
Oct 28, 2012 | Sanyo Televison & Video
Need to find list/definitions of "function Keys"
Please open this LINK, scroll down to page no. 2-5 i.e. the section with "To use the Function Hot Keys Fn". There you'll find the details about the functional function keys of your compaq. It seems your function key i.e. Fn key is activated, to deactivate, press and hold down the Fn key while you tap the Numlock key once.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 26, 2011 | Compaq Computers & Internet
When typing or using the back space key the letter a keeps coming up and I have to constantly delete from the words I'm typing?
we have to make sure if this is an issue with the key board or if it is with the software, it is very simple, all you need to do is, just plug an external key board (USB type) and try using it, if you do not have any issue with the external key board the you just need to replace the key board of your laptop.
If you are having the same issue or something similar to the current issue, it is evident that you have some kind of virus in the computer. have your system scanned with an antivirus software.
Hope this helps.
Apr 07, 2010 | IBM ThinkPad T41 Notebook
How do I remove the keys from a Roland KR 4700 piano? We can't figure it out. Please help! I can't afford to get a repairman. I need to replace the contact strip. It's happened before.
If these are semi weighted keys here is a cut and paste from a manual:
19. Disassembling the Keyboard Assembly
* After inserting a round stick (Rod: TX000670)
between the frame and the keys, remove the
circuit boards. (Fig. 23)
19-1 GHD EBUS L, MK SUB Circuit Board
(Time required: about 12 minutes)
Remove the seven (7) screws marked [260A]. The
GHD EBUS L and MK SUB circuit boards can then
be removed. (Fig. 24, Photo 5)
19-2 GHD M Circuit Board
Remove the five (5) screws marked [260B] and the
screw marked [262]. The GHD M circuit board can
then be removed. (Fig. 24)
19-3 GHD H Circuit Board
Remove the four (4) screws marked [260C] and the
screw marked [262]. The GHD H circuit board can
* Keys can be removed without removing the
circuit boards.
* After removing the GHD EBUS L, GHD M and
GHD H circuit boards, and the rubber contacts
can then be removed.
19-4 Rubber contact
Remove the GHD circuit board for the involved key.
The rubber contacts can then be removed.
The rod is inserted above the weighted hammer and the bottom of the keys from one end. It appears to be about 1/4 inch diameter dowel and will run the full length of the keyboard. You might use 3 foot ones from each end.
Screws are removed and the boards removed without taking the individual keys out.
Mar 17, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
How to remove piano keys from Roland KR 4700
You probably need to just clean the circuit board and the conductive rubber contacts. There are two per key to facilitate reading the key velocity.
Use 99% isoprophyl alcohol and Q-Tips to clean both the board and the rubber contacts.
A rod is inserted lengthwise to hold the hammer weights while removing the boards. Use dowels from each end inserted about halfway back between the keys and the weight rods. Use a 1/4 inch dowel rod.
You have to take out a few screws to remove the boards from the key assembly. Be careful of the cables.
Unable to input telephone numbers to fax document
THERE MIGHT BE A PEICE OF PAPER HOLDING DOWN A SENSOR, YOU WILL NEED TO CHECK OR THE OTHER POSSABILLITY IS THAT THE PHONE BOARD IS BAD AOR YOU MAY HAVE A STUCK KEY, THE KEY BOARD IS NOT A BOARD IT IS A PLASTIC  WITH PRESURE SENATIVE KEYS UNDER THE KEY BUTTONS GOOD LUCK
Oct 28, 2008 | Brother IntelliFAX 4100 Laser Fax
EEEKit Portable Office 4-in-1 Kit for 8 Inch Tablet Winbook Tw801 Tw802 ASUS VivoTab 8 M81C-B1-BK HP Stream 8 32GB Windows 8.1 Nextbook 8 Windows 8.1 Samsung Galaxy Tab 3/4 Note Pro 8.0 Le Pan Mini 8 TC802A Verizon Ellipsis 8 Logo
280 people viewed this question
Top EEEKit Computers & Internet Experts
Tom Chichester
Mister Danger
R.A. Ellis
R.A. Ellis
Are you an EEEKit Computer and Internet Expert? Answer questions, earn points and help others
