Black screen Keyboard doesn't type
  • 5,631 Answers
Does your computer start up? Can you get in BIOS pressing DEL or F!?
If not, probably your keyboard stopped working. Computer won't start up without a keyboard. so you should ge a new keyboard
If it starts up, you can set BIOS, then you've got a bootup issue. In best case it's just some boot file, wors case, your hard disk.
It is not possitble to tell what's happening without more information
Posted on May 02, 2015
Started typing multiple letters when only one key is touched.
Sounds like a physical malfunction of the keyboard - in your position, I would replace it. You could try to take it apart (which is easy) but re-assembly can be tricky.
Jan 04, 2016 | SIIG JK-WR0612-S1 - Wireless Ultra Thin...
Black screen enter password
after typing your password and once the screen goes black again press [ctrl+shift+esc] this will open task manager
then click file > new task (run)
and run explorer.exe.
your desktop should open up
Jan 02, 2014 | ASUS Computers & Internet
Samsung p6800 screen keyboard displaying wrong characters
I could be wrong but it sounds like your keyboard layout is set to swype instead of qwerty. On the bottom left of the keyboard is the setting option.
Dec 01, 2013 | Samsung Black Leather Case For Galaxy Tab...
Change password
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
Click "Start" icon in the lower left corner of your computer screen
Type the word "run" in the window that appears.
A second pop-up window will appear; type in the letters "cmd," then select "OK."
This will bring up the black DOS command screen.
Type next to the administrator account the following command: net(space)user(space) the username(i.e. johnadams) *. After typing this command, hit "ENTER" on your keyboard.
Type in a new password in the command screen prompt that ask you to type a password. Type the new password again once you are asked to confirm.
Type the word "Exit." This will bring you back to your login screen.
Enter the new password that you selected.
Sep 22, 2013 | Computers & Internet
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
My touch keyboard doesn't work
You need to recalibrate your touchscreen. If the screen can not be recalibrated, then it needs to be replaced. Please see this link on how to recalibrate your touchscreen:
Use the Nuvi 14xx procedure
http://www.sharc.net/discus/messages/6/77.html?1315261162
Apr 10, 2013 | Garmin Nuvi 50 LM
The enter key doesnt work
What program are you trying to access ?
The enter key is usually used for DOS command prompt.
or when typing in passwords to enter certain programs or computers and email accounts
click stat type into search cmd press enter a black screen should open
It might be a problem with the actual enter key on your keyboard.
Gather your supplies. There are commercial kits available, but a can of compressed air, a lint-free cloth or wipes, mild dishwashing liquid, and a vacuum cleaner with a soft brush are all you really need for a basic cleaning. After turning off your computer and unplugging your keyboard, gently shake the keyboard upside down over some newspaper to dislodge loose crumbs and particles. Use the can of compressed air to blow a stream of air between the keys. Repeat Step 2. Dampen a lint-free cloth with a diluted solution of dishwashing liquid and water to wipe down the keys. Use the vacuum cleaner brush attachment to suck away any remaining dirt or debris. If you have a membrane-type keyboard (it doesn\'t have a spring under each key) and the keys are truly grungy, you can remove the keys with a small screwdriver and use cotton swabs and 90% isopropyl alcohol to get it sparkling clean hope this helps
Dec 10, 2012 | Panasonic Toughbook 19 Laptop Convertible...
Asus p7h55-m black screen when i installed video card.. then i thought my video card is not functioning.. i get it and use on board vga.. its the same problem.. black screen, keyboard no light.. no si
Have you tried removing the new video card? Try that first.
The fact that your keyboard doesn't light most likely means that either your power supply is being pulled down by the video card or is now gone. Was your power supply rated high enough wattage for your computer with the new video card? If the video card was higher-end then it's possible that it killed the supply.
It could also be the motherboard that's gone. Static discharge when putting the video card in, or a bad video card can destroy a motherboard.
May 31, 2012 | ASUS P7H55-M LX Motherboard
Keyboard locked on m14x laptop
replace the key board it doesn't cost so much
Mar 10, 2012 | Dell Alienware M14x Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
