Question about Dynex 32 in. LCD Flat-Panel HDTV
Adjust picture to fit screen
The picture is square instead of the same/size of the actual screen.
  • Dynex Master
  • 5,631 Answers
Check physical setup buttons, probably it is on 4:3; change it to 16:9
Posted on May 10, 2015
  • Dynex Master
  • 3,320 Answers
Change the screen resolution in your Operating System desktop.
In Windows, click on Start/Help/ enter "screen resolution" in search field.
Posted on May 02, 2015
Carnt get normal screen on my tv the picture is always to large
Look for an option in your TV settings that allows you to adjust the screen size, once found, adjust to your actual TV screen and it should in theory fit perfectly.
May 31, 2015 | Televison & Video
How do i adjust the picture to fit thescreen on my toshiba flat screen tv
Hi, T
There will be a key on the remote control to adjust the picture size. You can adjust the picture size of your choice using this key.
Oct 11, 2014 | Toshiba Televison & Video
Are one-size-fits-most Helmets any good or should I prefer a more fitted helmet?
These types of helmets are good because they can be adjusted. They have a custom fit system that allows you to adjust them to different head sizes. This way you can actually have 1 helmet instead of 2 in case that you and your family members are not rafting together.
Feb 03, 2013 | Boating
Can anyone identify this PC Wallpaper
that's probably that your wallpaper isn't fit with your monitor resolution,for example,if your wallpaper size is 1280x1024 but your screen resolution (size) is 1024x768,it doesn't fit your screen and the wallpaper will only show half or even less
to check your current resolution,click
Start->Control Panel->click Appearance and Personalization->Click "adjust screen resolution" on the Display categories
you can see your current resolution and also you can set your resolution
To check the picture resolution,right click on the picture,select properties,click the Summary tab,and it doesn't show the resolution, click Advanced on the Summary tab
But I suggest you to download the wallpaper with a fit size instead of changing the screen resolution,because too high resolution will make your screen goes black
geez,i'm so sorry for my poor english
please rate this solution if it's work and let me know if you still has a problem.and thanks for using Fixya!
Aug 28, 2012 | Toshiba Computers & Internet
White stripe on screen
Unfortunately it seems that each time I turn the tv on and off it resets the screen position and I have to adjust it each time.
I would assume that my set would remember the settings.
Use Picture Size, not Picture fit. Set it to 16:9, instead of Fit To Screen. There's a handy button the the remote for this: P-Size. And the setting sticks between shut-offs.
What you are seeing is called "overscan", extra information that most broadcast stations send, because most old TV's were set to zoom-in/crop the signal they received. So.. with new TVs, like your Samsung, you get the choice between size "Fit to Screen" which is 1-to-1, for pixel-accurate inputs like Blu-Ray and DVD, and size "16:9" which is really "support for overscan", for old, less precise signals like broadcast.
Mustang Parts.
May 28, 2012 | Samsung Televison & Video
I lost my remote, and the picture is smaller than the actual screen by about 2-3- inches on all sides. how do i enlarge the picture to fit the screen?
This function u can't do it without the tv original remote.Try website like Remotes.com to buy the tv original remote.Than used one of those buttons on the tv remote like View Modes,Picture Sizes,Aspect Ratio,Zooming to do the adjustment for tv screen pictures sizes.
Jun 23, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
My tv's picture does not cover the entire size of the tv. The picture that shows is the size of a square and my television is a rectangular size. How do I widen the picture?
there should be a button on your remote that adjusts the picture to fit your screen. They have that on most tv's. Are you using a cable box? your cable box also has settings depending on what your using. 1080i, 720p? does it do the same thing with a dvd player or game console hooked up?
Mar 02, 2011 | Sylvania LC370SL8 37 in. LCD Television
Only half the picture is printing?
The printer may be runnung out of ink or requires alligment adjustments to fit into the printing paper. select portrait or landscape printign formats to fit pictures. esle, attempt to print small size pictures instead.
Jan 29, 2011 | Kodak EASYSHARE Plus Series 3 Thermal...
Can you make horizontal pictures fit the frame
I'll assume your picture is already oriented properly (horizontally), i.e. you do not need to rotate it.
There are 2 modes for displaying the photo ... (1) the ORIGINAL mode - displays the photo in actual photo size, which may result in part of the photo not being visible on the screen, or, (2) the OPTIMAL mode - which reduces the size and resolution to best fit the screen.
To set image size mode, select the SETUP on the HOME screen display, then highlight and select the DISPLAY IMAGE SIZE button, and go from there.
The first (ORIGINAL) mode is usually the default mode. When you select the OPTIMAL mode, the picture will be scaled to fit the size of the screen ... but you may see "dark" bars (e.g. on top and bottom of the screen) if your picture does not fit the exact screen size.
Jan 02, 2011 | PANDIGITAL 8.0" Digital Photo Frame...
Picture to large for screen
hit your aspect button or fomat button on your remote it will adjust size of picture also verify cable box aspect ratio
May 08, 2009 | Televison & Video
Dynex 32 in. LCD Flat-Panel HDTV Logo
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
