Question about Konica Minolta Minolta Bizhub 160 Copier Printer Scanner WITH PLATEN COVER
Machine trouble service call c3451 what is the problem?
  • Konica Minolta Master
  • 3,320 Answers
Here is the answer Thread BIZHUB C352 RESET C3451
Posted on May 02, 2015
My xerox machine model is Konica Minolta Bizhub 164. machine trouble service call (C3451) showing on display. what should i do?
C3451 Description Warming-up failure
- The surface temperature of the fusing roller does not reach a given level even after the lapse of a given period of time during a warm-up cycle. Remedy 1 Check the fusing unit for correct installation. 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 5 Change PRCB. 6 Change DCPU.
Jan 12, 2015 | Xerox Office Equipment & Supplies
Why printer shows machine trouble when connected?
Fusing warm up.Remove the fusing unit and check the heater lamp and thermistors.
Aug 05, 2014 | Konica Minolta Office Equipment & Supplies
Machine trouble Service call(c3451)
Sir/Mam,
On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover, with the machine on use a small screw driver and gently depress the small black switch. The machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. The code will come back but now press the Utility/Counter button, you should see a button that says Maintenance Mode press that, see Trouble Reset press that and the machine will again will go thru warm up procedure, you will see the "." DO Nothing! The machine should go to "Ready to Copy" if the code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
Feb 01, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Getting c3451 error
There is no c3451 code in the bizhub 350 service manual.
Feb 20, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Service error code
C3451 Heat. Heater Trouble • The Heating Roller Thermistor/1 (TH1) and the
Heating Roller Thermistor/2 (TH3) fails to raise a
given degree of temperature even after the lapse
of a given period of time after the Heating Roller
Heater lamp/1 (H1) is turned ON.
• The detected temperature of the Heating Roller
Thermistor/1 (TH1) is lower for a given level of
degree than one of the Fusing Pressure Roller
Thermistor/1 (TH2) after the Front Door is opened
or closed, the Main Power Switch is turned ON or
TROUBLE RESET is implemented.
• The counter value of zero cross signal input is not
updated for a given period of time.
To reset:
Functions • If the all troubles occur and the status would not be cleared by turning Main Power
Switch OFF and ON again, or opening and closing the front door, clear the status of
the machine.
Use • To be used when the status would not be cleared by turning Main Power Switch OFF
and ON again, or opening and closing the front door in case of a trouble.
Setting/
Procedure
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Jan 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Minolta Bizhub 160 Copier Printer Scanner WITH PLATEN COVER Logo
318 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
