Question about Frigidaire Dryers
E61 appears on my electric frigidaire dryer, an there's no heat.
    Problem Solver:
  • 27 Answers
Faulty heater relay, will probably need to replace main board.
Posted on May 05, 2015
Replaced heating element now I get error E61, I ohmed out the thermostat on top of heating element seem to be ok
Hello Louie, I appreciate your inquiry!
Based off the information you have provided your Frigidaire dryer is displaying an error code of "E61" after you have replaced the element. An "E61" error code means that there could be an issue with your heater relay or main control board. You may need to seek additional assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Mar 28, 2016 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
Replaced circuit board and i have heat but still shows e61 code
Hello friend, thanks for your post!
Based off what you have described your Frigidaire dryer is displaying an error code of E61. I understand that you have replaced the circuit board and you are still receiving the error code. An E61 means that your heater relay as had a failure which could be a potential problem with your heater relay or a wiring harness. You may need to seek professional assistance with proper troubleshooting this will help you to avoid any further unnecessary part purchases. If you need help locating a local technician you can visit your manufacturer's website for a list of available technicians. -Matt
Aug 05, 2015 | Frigidaire Dryers
Frigidaire affinity dryer error code e61. What does it mean
Error E61 points to a bad heating element relay. The heating element relay is on the main control board, and is not supposed to be replaceable. A new control board will run you over 100 dollars, but the relay is most likely 15 or less. If you or someone you know is handy with electricity and a soldering iron and a voltmeter, verifying that your heating element (or its wiring) is not dead and that the relay is indeed defective should be diagnosed first.
25448593-xipalmoknr3fbjmp51kycajc-2-0.jpg An example board: one of the large black cubes is the heater relay. On the other side of the board, there may be a burnt trace or a bad solder joint. In that case, the relay may be OK.
Your dryer will have a mini-manual or tech sheet inside it next to the control board somewhere with a wiring schematic and parts list. You can plug these part numbers straight into a search engine to price components and determine availability.
Feb 19, 2015 | Frigidaire Dryers
I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called frigidaire. they said it was likely a shorted wire and put me in contact with an
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
Dec 20, 2014 | Frigidaire Dryers
Electrolux
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
May 01, 2013 | Frigidaire Electric Dryer
Error 61
Looks like E61 is a heat relay related.
Does the dryer heat OK?
Nov 26, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Replaced control board on dryer still getting e61 code
The problem is not with the dryer as confirmed by the other identical dryer brought by the dealer. The problem is in the wiring of the receptacle where the dryer is being plugged in as characterized by error code E61 which means the control board is receiving a high voltage. The dryer operates both on 110VAC for the controls including the motor and 220VAC dedicated for the heating circuit. The receptacle must be configured according to the specifications of the dryer. Refer to the diagrams below and configure the receptacle according the plug that came with the dryer. Voltage across L1 and L2 is 220VAC, L1 and Neutral is 110VAC, L2 and Neutral is 110VAC.
Nov 17, 2012 | Frigidaire Electric Dryer
Brand new Frigidaire Electric Dryer gives Error E61. Store brought out another identical dryer with same result. Help please!
Note: You may need the service of a certified electrician for this task.
Jul 13, 2011 | Frigidaire Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
