When I shut the top it won't start, like the switch doesn't engage?? Used to slam it a lil hard and it would start.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Change lid lock should solve prob
Posted on May 02, 2015
Lid lock broken can I overide?
Washer not starting Cycle:
I would have to slam the washer lid before the washer recognized the lid was shut.
What I did to fix:
1. Ref the link below for Schematics
http://blog.kennyluong.com/Tricking-A-Maytag-Bravos-Washer/
2. Looking at the Lid Lock section of the Schematic:
Place a jumper between pins 2 and 3 of J15
This engages the 1st switch (Lid Lock) so, I don't have to slam the lid anymore
3. Since my Lock switch (2nd switch), which is engaged with a magnetic, is working, my work is done.
If you find that your machine is still not starting the cycle, you will need to
replace the Lid Lock mechanism or ref the above link for temp bypass.
Mar 30, 2014 | Maytag Bravos Top Load Washer
2003 gmc envoy 4x4 problems. 4200 vortec engine. my front diff doesnt seem to be working
Look under there and see, but I think they (the hub locks) are engaged by vacuum motors.
May 18, 2017 | 2003 GMC Envoy
Maytag bravos x lid lock overide or bypass
dpthom's wife is the smartest woman on earth! :)
Feb 11, 2013 | Maytag Bravos Top Load Washer
Lid lock button is flashing and wont unlock
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
Jan 08, 2013 | Maytag Bravos MTW6600T Top Load Washer
Indesit wil 153 door red led is flashing after I set washer settings, doesn't start cycle ?
The flashing light means that the machine thinks the door is not closed (The door lock switch is not activating). 99% of the time this is simply a sticky switch and the solution is to give the door a good firm slam shut (Don't get silly here, but it will take a pretty good "teenager slamming the bedroom door in a temper tantrum" type slam).
In the event that this doesn't work, then you're looking at a faulty door interlock switch. They're not that hard to obtain or fit if you're fairly confident. Drop me a comment back here and let me know how you get on. Happy to help further if the above hasn't allowed you to solve the problem.
Aug 15, 2011 | Indesit W 123 Front Load Washer
I have a kenmore elite dryer hE4. the dryer will run for a while then shut off... and will not restart for a while, i have changed the moisture sensor, thermistor, thermal fuse, the moisture sensor wire...
its a door switch problem. Make sure the door is latching properly at the top. If the top latch doesn't engage properly the door switch won't make contact.
Try holding the door switch closed with your finger and starting the dryer. If it still wont start and you have no error codes displaying you will most likely have to replace the switch. if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Apr 13, 2011 | Dryers
Where is the fuel shut off switch and how to reset it on a 2000 Ford Explorer. I have replaced the fuel filter, it was running fine, then just won't start (cranks and cranks) and someone suggested it may...
The Inertia Fuel Shutoff is located in the trunk, on the LH hinge support.
All you need to do is press the reset button located on top of the switch.
Oct 20, 2009 | 1989 Ford Tempo
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
