Question about Whirlpool Washing Machines
Lsr5132pq0 my machine quit working. The dial is loose and I can't get it engage. It stopped with water in the machine. It isn't draining.
Here are the numbers from the sticker on it. cr3626141 lsr5132pq0 whirlpool111
    Genius:
  • Whirlpool Master
  • 1,585 Answers
Check pump for blockage
Posted on May 02, 2015
My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
Jan 25, 2014 | Washing Machines
Frigidaire front loading washer drainage
Hello - Is the washer draining or not draining? If it is not, this particular issue could be caused by a variety of reason. I would suggest trying the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Oct 01, 2012 | Frigidaire Washing Machines
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Model GSD3620Z02BB - The normal cycle will not engage when the knob is turned. The short cycle will engage (sound like it is working) but the soap is left in the reservoir and about 2 inches of water is...
Sounds like the selector switch has gone bad. The machine is not fully cycling thru and draining because the selector isn't proceeding like it should.
This typically happens if the selector dial is spun real hard repeatedly over time. The little cogs inside of the selector will get broken and sometimes the broken parts will lodge inside the switch and cause jams.
May 27, 2011 | Maytag Dishwasher
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
My kenmore 800 top loading washing machine just quit it wouldn't drain the water out and it wasn't spinning? It does make the sound of working when I pull the start dial but nothing happens
check the belt motor if loose or lost or it came out or broken. the belt is at the bottom of the washer. Remove the water using a cup and slowly and be carefull laying sideways the washer, then you will see the belt there, if you can not see the belt, that washing machine is a tranmission type machine, need to call Sears apliance service. ok
Nov 22, 2009 | Pool & Spa
Water does not drain
either dial has went up or the pump has
Jul 01, 2009 | Washing Machines
Control dial moves along fine but drain,spin, rinse never happen
replace the water pump. about 46 dollars and a 20 minute job.
Jun 24, 2009 | Maytag Washing Machines
Stopped during a cycle and has no power.
Most likely lid switch is broken
Part number 8318084
May 18, 2009 | Whirlpool LSR5132PQ Top Load Washer
My top loading whirlpool washer stopped after filling. Cycle dial does not engage any agitating, spinning,rinsing, nor draining activity. The dial does not advance with time, neither. Checked the outlet...
You could have a bad lid switch or a bad water level switch or a bad timer. In that order.
Open the control panel to access the components listed.
Make a small wire jumper and jump out the lid switch. Turn the timer on and see if it works. If yes, replace the lid switch.
If no, check power from the water level switch to the timer.
Terminals V to T should read closed on a meter set for ohms.
If the water level switch is closed the timer is bad.
Apr 22, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
