Question about Singer Sewing Machines
Why does the bobbin thread jam up on my Singer sewing machine?
  • Singer Master
  • 9,530 Answers
If you have adjusted the tensions as previously suggested by Bill Boyd and it is still causing a problem, then you might try manually pulling the bobbin thread to the top of the fabric and then holding it with your left hand before beginning to sew. A lot of sewing machines will cause thread nests when first beginning to stitch. This is a way to avoid the problem. You can ignore the references to quilting and free motion quilting. However, the method for bringing up the bobbin thread will work for regular sewing as well:
How and Why to Bring up the Bobbin Thread
Posted on May 03, 2015
Testimonial: "Thanks for your help -- just what I needed to do!"
    Top Expert:
  • Singer Master
  • 42,712 Answers
Thread tensions will be at fault here
if there are loops under the material then tighten the needle thread tension
otherwise tighten the bobbin thread tension
Posted on May 02, 2015
  • Anonymous May 04, 2015
    Thanks, Bill Boyd. Your answer is appreciated! My Best To You, Paula
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 56 Answers
Sounds like the tension, find a good sewing machine mechanic and pay for a service, well worth the lifetime of the machine.
Posted on May 04, 2015
Sewing machine is jamming on first turn permanently
Your bobbin may be in backwards. Is it possible to put it in either way?
Mar 01, 2014 | Singer Co Singer Talent 3321 Sewing...
My new singer sewing machined gt jammed most of the time with the underneath thread all clumped.
try changing the needle
check to see if the top thread is coming off the thread take up lever
check to make sure the bobbin is turned the right way & inserted
into the needle case correctly
Aug 09, 2012 | Singer 4423 Sewing Machine
I have a Singer Touch and sew 600e, the bobbin thread is all bunched up and machine jams up with thread. How can I fix this? Is there a simple setting that I am missing.
rethread the machine top & bobbin
make sure the bobbin is inserted correctly in the bobbin case
make sure the top thread is not coming off the thread take up lever
make sure the bobbin is wound correctly
if these suggestions don't work, I suggest that you take the machine
to a sewing machine shop to have it checked
Aug 06, 2012 | Singer Sewing Machines
Singer bobbin thread not being caught
try rethreading the machine top & bobbin
change the needle--flat side to the back of the machine, make sure the needle is the right one for the fabric being sewed
clean under the needle plate & in the bobbin area for lint or theads
May 10, 2012 | Singer 3323S Sewing Machine
The thread hangs up inside the bobbin holder
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Sep 26, 2010 | Singer 2517 Mechanical Sewing Machine
My Singer 507 sewing machine keeps on jamming up, the thread gets wound around the bobin and jams. I have thread the machine as in the manual. PLEASE, PLEASE could you help.
If you have the 507 with the grey or black plastic bobbin case you may need to undo the two screws on the right hand side on the silver bit and push it over to the bobbin case so it is tight or enough gap between the bobbin case and the silver bit about a thread width.
Apr 05, 2010 | Singer 5070 Mechanical Sewing Machine
Singer simple the machine keeps jaming
I would say that the threading is wrong somewhere, watch your dvd and read the owners manual, also go to Singer.com FAQ for your machine, If the jamming is underneath, it is the top threading problem, on top, it is the bobbin thread either has lint or stray thread or thread not coming out the right direction for your bobbin, I am sure that it is just a simple solution, I also use metal SA 156 bobbins and have no problems,
Apr 05, 2010 | Singer 3116 Simple
Keeps getting jammed
Give these solutions a try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin as there could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting jammed in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Singer advance 7422
My Singer 7422 seems to be jammed. When I start to make a stitch, the thread from the needle gets caught on something on the bottom and the thread goes over the bobbin.
Jul 16, 2008 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
94 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
