Question about AEM 2001 Ford Ranger - 4.0L V6 - Brute Force Air Intakes
I have an intermittent misfire on one cylinder.
I replaced plugs, wires, coil pack and it still misses.
  • 991 Answers
Spark plug wire is the main cause, have a look under the bonnet with the motor running. Do this at night or in a dark place and look for sparks.
Check the wiring and connectors from the coil pack back into the loom and up to the ECU/ECM. If the wiring loom, coil packs and spark wires are all good it must be the drivers in your ECU/ECM.
Posted on May 02, 2015
  • 2,825 Answers
Could be bad connection to injector or bad injector?
Replaced coil pack on 3800 pontiac bonneville and its still missing what now?
First you need to determine what type of miss you have. Is it random on all cylinders, or is it restricted to one or two cylinders? Random misfire can be caused by crank or cam sensors that are starting to give out. Single cylinder misfires can be due to plugs, wires, coils (you already addressed those), as well as internal issues such as burnt or broken valves.
Oct 23, 2015 | 2000 Pontiac Bonneville
Why won't my car start?
P0300 multiple misfire
P0302 misfire cylinder 2
P0306 misfire cylinder 6
Apr 25, 2015 | Cars & Trucks
MISFIRE ON CYLINDER 4 AND 6 WITH AN ENGINE LIGHT ON
Check the coil packs on the plug if equipped with that type, or the coil packs at the end of the spark plug wires, if so equipped.
Also, check that the fuel injectors are firing on all 8 cylinders.
Definitely, check out what other codes are stored in the computer besides a missing condition.
I have a 1999 Expedition that had a miss on a cylinder, and it turned out to be a bad coil pack. You have 2 cylinders missing, so I would check each cylinder for good spark, or replace the coil packs as necessary to see if that resolves the problem.
Good luck on this repair.
Dec 31, 2010 | 1997 Ford Expedition
I have a 2002 TrailBlazer with the straight 6,diognostic check said #3 cylinder was dead or misfiring, also map sensor showed up. #3 cylinder was misfiring, so to test the coil pack I swapped #3 coil pack...
did you replace only one spark plug? that can cause issues because of differences in resistances between cylinders. also, did the map code stay off after replacing
Feb 28, 2010 | 2002 Chevrolet TrailBlazer
I have a ford explorer 99 but it's giving a error code PO306 what do u think it is
It sounds like a misfire. Check spark plugs 5 and 6. It could be bad fuel, bad plug wire, or weak coil. Check the fuel injectors as well. Other possible causes could be an egr valve stuck open, vacuum leaks, low fuel pressure.
Feb 17, 2010 | 1999 Ford Explorer
2002 Ford Tarus intermittant missing cyl #3 after tuneup
I would remove one plug at a time, plug it back in wire and lay on top of engine block. Have some one crank and look for spark. Do this for each plug. If 1 is missing. You have bad wire. If two sparks are missing, then you have bad coil pack, if 3 is missing, you have two bad packs or bad module, if all cylinders are missing, then module or cranks sensor is faulty. Dont forge to change those plug wires just as often as plugs. They may look good still, but they get weak
Sep 11, 2009 | 2002 Ford Taurus
5.3 L Missing and Rough Idle Intermittently
i have a 2001 chevy z-71 5.3L. I keep getting a random/multiple misfire code for cylinder 1 . I have replaced plugs, wires, coil pack(only on #1 cylinder)., and fuel pump. I still keep getting the cylinder 1 misfire code. I put truck on a scanner and watched the cylinders. # 1 misfires at idle but quickly stops misfiring at around 1000 rpms. you can here the engine miss at idle but truck runs great on road . anyone else ever had this problem?
May 05, 2009 | 1999 Chevrolet Silverado 1500
Engine not hitting on two cylinders after replacing cam sensor
If you have a coil pack with 6 cyl. 3 coils in one One coil for 2 cylinders One of the coils in the pack has gone bad. To verify this check which cyliders are missing and see if they match any pair on the coil pack. If so the coil should be replaced. Hope this helped. Moe
Apr 28, 2009 | 1998 Plymouth Grand Voyager
Missing out
that would be a good start. pull the plug on # 1 cylinder and plug into wire now crank engine you should get spark same as # 5 cylinder if no spark replace the coil pack
Apr 18, 2009 | 2003 Ford Taurus
AEM 2001 Ford Ranger - 4.0L V6 - Brute Force Air Intakes Logo
64 people viewed this question
Top AEM Tools & Hardware - Others Experts
Lawrence Oravetz
terry stevens
Are you an AEM Tool and Hardware - Other Expert? Answer questions, earn points and help others
