Question about Sewing Machines
I have a White model 3900N. Why does it only sew in reverse?
    Sergeant:
  • 333 Answers
Hello Jan, I have run into this problem many times. The reason your machine only sews in reverse is caused by old sticky oil at the feed dog pivots. Oil your machine with only high quality sewing machine oil. Pay close attention to the two pivots under your machine where the feed dogs attach to cross journals. Oil them several times and work the reversing lever until the feed dogs move freely and easily. It will sew in reverse if you oil the pivots. Good luck.
Posted on May 02, 2015
2 Suggested Answers
SOURCE: how to thread white 3900N?
contact singer customer service about a manual
sewingpartsonline.com
sew4less.com
sewusa.com
youtube for video's
Posted on Apr 23, 2012
Machine will only sew in reverse
You wrote,
"Machine will only sew in reverse - Sewing Machines" A: I'm just a tinkerer, hobbyist, who did run across this same problem before. I can give a general non-model specific remedy based on my limited experience with mechanical sewing machines that get locked into sewing backwards, that is "they only want to sew in Reverse":
1. Verify what is the normal direction of the fly wheel in forward sewing for your machine. Most sewing machines, including Singers, always sew with the top of the flywheel moving toward the operator, regardless if sewing forward or backwards; but older friction-wheel White Rotary (RF) sewing machines, have the flywheel running in the opposite direction (top of Hand-Wheel turning away from the operator when sewing.
2. If it has Reverse Lever/Switch; check that it is in the correct position; if still only sews in reverse, change positions of the Direction Control lever (or Button, etc.), and see if it changes direction to correct the problem.
3. If this does not help, then jiggle the Reverse Lever and follow the linkage inside the machine and see if there is anything broken, loose or out of adjustment. Some machines have reverse control linkage elbows in the top part of machine, and by poor design are prone to accidentally pop backwards, causing sewing in the opposite direction of the position of the Reverse Lever/Button (Backwards when you want to sew Forward). On occasion, a Kenmore 158.1787180 got locked into the backwards sewing mode (the dog-gone' est thing), but by following and analyzing the linkage, I found where it was going wrong, and popped the indecisive linkage elbow back the way it was supposed to be and fixed it. [ I had more detailed notes, on this fix, but when I read them, without the machine in front of me, made no sense to me today so I can't share that till I revisit the conundrum again.]
4. If all else fails, you may be able to hold or clamp the Reverse Lever/Button in the Reverse position, so it sews Forward (I've done this before too (as a short-term fix) until I figured out how to adjust it back the way it was supposed to be.
5. If this post helped you, don't be afraid to indicate so, so Fixya will know. If it was useless, "ouch", but I'd like to know that too, so I'll be more selective on what I really know more about. I try to help, though this is probably a trade secret that anyone who knows is discrete about who they share the information with.
Sincerely
-- Amender. (2016 FEB 24)
Feb 06, 2016 | Sewing Machines
Need the manual for model 534?
SINGER 534 MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Singer Manuals > Sewing Machine > 534
View and Download Singer 534 manual online. Stylist Sewing Machine. 534 Sewing Machine pdf manual download.
[PDF]White Sewing Manual Model 534
www.masepmadit.com/white-sewing-manual-model-534.pdf
vw instruction manual, white 534 serger: sewing parts online understandable ... techmanual white superlock serger model 534 repair manual compiled pdf.
Jan 07, 2016 | Sewing Machines
I need a reverse lever for my White Quilters Star model 1780. Do you know where I can get one?
You probably won't be able to find one unless it is used from a donor machine. Try eBay or some other online parts suppliers. Your local sewing machine repair shop may be able to "create" something for you.
Where is reverse button
Depends on the make & model of your machine. Would be best to consult the owner's manual. Mechanical and computerized machines also vary. Mechanical machines usually have a stitch length lever that, when pushed all the way up, will reverse stitch, or there is a button usually marked with an R or an arrow. Computerized machines usually have a button marked by a U-shaped arrow.
Of course, if you have a vintage sewing machine, it may not even have a reverse stitch. Instead, to sew in reverse, one would have to sink the needle into the fabric, raise the presser foot and swivel the fabric 180 degrees, drop the presser foot and stitch.
To find a copy of the owner's manual, search the internet for:
Manufacturer + Model + the word "Manual"
sewing machine reverse Google Search
Dec 04, 2015 | Sewing Machines
How do I get a Service manual for an Industrial Sewing Machine
If the handwheel is really stiff and the machine is making awful noises, then your machine may need oiling. Don't know if this is the case with your industrial machine, but it may be something to consider.
Jun 12, 2014 | White Sewing Speedylock 1600 Mechanical...
Creations 3 is sewing in reverse reverse button not lit
All serging machines run in reverse, the hand wheel turns reverse compared to regular straight stitch machines which run counter clock wise. I need more information, My email is rtarkington2@cfl.rr.com.
Jan 24, 2014 | White Sewing Speedylock 1600 Mechanical...
Why is my creations 3 sewing in reverse when the revrrse button is not lit
Push and hold the reverse button for 7 seconds and see if that fixes it.
How to thread white 3900N?
sew4less.com
sewusa.com
youtube for video's
Apr 22, 2012 | White Sewing Sewing Machines
Does the bobbin on a white 1418 thread clockwise or counter-clockwise?
You can download a manual from here http://www.singerco.com/accessories/manuals.html, just type in the model number and click on 'search' to locate your machine's one.
As a rule of thumb, the thread usually comes off a bobbin goes through the tension then reverses direction back the other way. So as you pull the thread, the bobbin usually turns anticlockwise. But always check the manual to be sure.
May 22, 2011 | White Sewing 1418 Mechanical Sewing...
Thread tension is bad only when reverse stitching
forward stitch is great but reverse is loose . What should I do
Dec 14, 2010 | White Sewing 2037 Mechanical Sewing...
Sewing Machines Logo
97 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
