Question about WHITE-RODGERS DIV 1F80-361 Classic 80 Series Thermostat, Single Stage, 511 Programmable
Why does it indicate temp of 90 when it is only 72?
I changed batteries with no effect
    Problem Solver:
  • 4 Answers
Is the 90 degrees the set/desired temperature
Posted on May 10, 2015
Temp shows 90 when it is only 72- I changed batteries - no effect
what do you need temperature on the camera for if you already know what the temp is??,your camera needs to be in the shade to be accurate
May 02, 2015 | Home Security
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
How to restart nokia5310
Hi whats the problem ? you mean your phone could not start up,or it is totally dead ? For nokia 5310 sometimes this problem cause due to im-proper connection of its battery,the connector of the battery gets open frequently,so first check it out Or if the battery fully drains.Put another battery and try,even if there is no effect insert charger.And if the charging is indicated the fault is power key.When charging indicated and your phone doesn't switch on then you need to change the Strip (Pata).Neverthless,contact mobile repairing shop.Thanks for visiting fixya.Good luck
Jun 26, 2012 | Nokia 5310 Cellular Phone
My Behringer fx600 multi effects pedal flashes rapidly when used with a power adaptor. this happens whether the pedal is turned on or not.
The LED is ALSO used as a battery condition indicator... this is probably indicating the battery is expired. The manual sure doesn't say much!
Apr 26, 2011 | Behringer Fx600 Multi-fx Digital Stereo...
I have a 1999 ford explorer with tthe overhead council that has two map lights and the outside digital temperature indicator. the lights still work, but the temperature won't display. I dropped it down and...
It could be the temp sender unit located in the engine compartment. Is this the only part of the console that is bad (ie the compass still functions)? Have you tried unplugging the battery to reset everything?
Aug 04, 2010 | 1999 Ford Explorer
System error e000
E000
The error history indicates any of the following error codes 4 times: E001, E002, E003.
Which relates to the fuser temp. you need to change the fuser unit.
Sep 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Wireing tempature gauge
Outside temp sensor located at inner fairing, it is tied to left fairing frame just above cigarette lighter.
On OEM parts,
Air Temp Gauge pin#1 = Orange +12 Volt
Air Temp Gauge pin#2 = Black - ground
Air Temp Gauge pin#3 = Air Temp sensor pin#1
www.bengkelsepedamotor.wordpress.com
Dec 27, 2008 | 2005 Harley Davidson FLHTCUI Electra Glide...
Freezing temperatures effect on LCD television
It shouldn't have any bad effects on the display. When LCD panels get cold they may exhibit slow response time, like trails or a persistent display when action is moving. As long as you don't experience SUDDEN temperature changes you should be OK
Oct 17, 2008 | Televison & Video
Preheat beep indicator is inaccurate
It's working ok. These often beep after a preset time. It may be set to beep at 10 minutes. Not always at the temp set. It is usually close enough though.
Nov 19, 2007 | Magic Chef CER3725AA Electric Kitchen...
WHITE-RODGERS DIV 1F80-361 Classic 80 Series Thermostat, Single Stage, 511 Programmable Logo
304 people viewed this question
Top WHITE-RODGERS DIV Heating & Cooling Experts
Lawrence Oravetz
Joe Lane
Are you a WHITE-RODGERS DIV Heating and Cooling Expert? Answer questions, earn points and help others
