Question about Boating
Changed trim relay. now no power to anything
Already checked fuses under consol
    Top Expert:
  • 10,875 Answers
Take out the relay
Posted on May 02, 2015
Got a 2002 honda accord. My turn signals wont flash. Ive already changed the fuse and the relay under the dash. Any suggestions?
were the fuse and relay bad if they were there's a short in wiring or switch ---check for power from switch
Aug 18, 2015 | Honda Cars & Trucks
I cannot start the motor or raise the tilt and trim. Have power to the starter solenoid. have powere to the starter
check the control box , use multi metre and check the trim button and ignition key ! check main harness socket on the engine for corrosion or breaks in the wires !
Apr 11, 2014 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
1996 caravan replaced fuel pump dont have power going to it ,, already checked and moved around the relays.. is there anything else i need to do?
you don`t say did you check the fuses.were the connections at the fuel pump plug in good/clean condition.have you check for power at the pump wires at the tank you do then you will have to check the pump wires at the pump if you don`t have power by the tank then you need to check to see if power is powering up the relay and going out of the relay to the pump.you could have a corrosion problem under the relay box.
Apr 28, 2011 | 1996 Dodge Caravan
Changed the headlights and checked fuses the reason why changed due to the lower beams not working and high working. Still no low beams but high beams are working perfectly
If you have already checked the bulbs to be alright then check if the bulb holders is having bad grounding. If this seems fine then trace back the light voltage to the relay unit, it could be the contacts have worn out or the relay is not switching according to the command from the driver's console multiple switch. Check the voltage flow to the relay before you can confirm on the relay. If no the multiple switch is not giving out the contact. You can use a test lamp to check on the power to all these circuits. Use a 12 volt lamp and ground one end, the other end you can touch upon to the testing line for the bulb to light up confirming the voltage . This way you wiill be able to identify the continuity of the circuit under test. I hope this helps. Good day
Jul 08, 2010 | Cars & Trucks
93 subaru leg wagion fuel pump problem
The fuel pump relay is located under the dash on the drivers side. The fuel pump relay is green and it should be next to a brown relay for the ignition.
May 22, 2010 | 1992 Subaru Legacy
My power windows in my 04 saturn do not work. No Power to the switches, already checked fuses, but no fuse listed on diogram for window. Whhat/where should I be checking?
I believe there are relays under the buttons on the center console. somehow the cover plate comes off. I have heard of it being done. same relays are used on an Equinox so a chevy dealer can help.
Apr 03, 2010 | 2005 Saturn VUE
300M Dash Gauge Lighting
I HATE Dodge's electrical system. I purchased a 2000 Neon from a junkyard to teach my son and daughter to drive. I refurbished it, but electrical issues had me using techniques I use in my home repair business to fix em. Okay. I'll get over it.
Before you order one of Dodge's expensive parts then find out that customer service sucks, try replacing the dash fuse. Check the relay under the hood in the engine compartment. The clock might use the same switch, but it MIGHT not have the same power supply. I know it sounds crazy, but this is the same company that has the reverse relay fuse located under the center console in the Neon. I'm sure you've already checked that your switch is in the on position, so I hope that changing the fuse and/or relay work.
Jul 27, 2009 | 1995 Saab 900
No power at fuel pump chev.S-10 looking for fuel pump relay and fuse
The fuel pump relay is located Under hood, driver side, upper firewall, mounted in relay block.
The fuse is located under the instrument panel to the left of the steering column. The fuse block should be visible from underneath the steering column, near the pedal bracket. If the panel is not visible, check for a removable compartment door or trim panel which may be used on later models to hide the block.
Jun 03, 2009 | 1992 Chevrolet S-10
Cigarette lighter not working, already changed fuse
Look in your manual for the Power Distribution Box reference in Roadside Emergencies. It should be located under the hood on the driver's side. My 2002 Explorer has two power points on the center console and the 20A fuses in the Power Distribution Box for them are number 7 and number 9. They cost $3.99 each at AutoZone. The cigar lighter fuse under the dash is unrelated.
Jun 02, 2009 | 2005 Ford F-150
BMW (E39)520SE 08/2001 Auto Touring. Rear wiper/washer has failed. I have located a replacement wiper motor but understand that 'the relay' is also prone to failure. I've still got the fuses to...
after making sure your fuses are ok, go in the trunk and behind the access cover where the battery is located. above the battery should be a fuse panel, which may be hidden under the insulation trim, there should be some fuses and relays there. the relay closest to the rear of the car is probably the relay you are looking for. you can try swapping it with another relay in the panel if the relays are the same. bmw always puts a part number on their relays. i would start with checking the fuses and relay first.
Mar 17, 2009 | 2001 BMW 5 Series
Boating Logo
96 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
