Question about Car Audio & Video
Can this rca jack be purchased and resolderd
Title says it all
  • 2,899 Answers
All except what "this" actually means.
RCA jacks are very available, and if you're at all good at soldering, you should be able to do one.
Posted on May 02, 2015
  • david May 04, 2015
    I'm a certified welded, I know how to solder, just that electronics aren't my specialty , thenk you very much !
Connecting a sound bar
Typically you will connect the RCA audio output jacks to the audio input jacks on the sound bar, but if your television does not have RCA audio output, you may have to buy additional hardware to make the soundbar work. If your TV has a headphone jack, then you will need to purchase an 1/8" Headphone connector to RCA Connector cable from a local electronics or audio store. If your TV doens't have any audio outputs, you may need to purchase a digital tuner box and connect it to your TV and soundbar.
Jul 19, 2014 | Sharp home theater system HT-SB300 User...
Tip
Where to use a Jack and Jack Stands on a Ford Crown Victoria and Mercury Grand...
Where to use a Jack and Jack Stands on a Ford Crown Victoria and Mercury Grand Marquis
on May 22, 2012 | 1998 Mercury Grand Marquis
Tip
HD52W140 White screen with retrace lines then shuts down
This has the ATC311 chassis. I have found that capacitor C14703 has actually been loose on the deflection board and that had caused the set to have a white screen with retrace lines then the set would shutdown. I resolderd this and normal operation was resumed.
on Feb 23, 2008 | RCA HD52W140 52" Rear Projection...
I picked this Emerson tv # EWL20S5B without any manuals, remotes etc. it has 8 rca jacks 1 s-video & a cable ant jack.HOW DO I WORK IT???? Anybody or does anyone want this for $1.00?
No remote with this brand is a real problem--most universals will not even program for this set and if they do will be missing key features needed.
GOOGLE the model number with "manual" to try to locate a owner manual.
Mar 31, 2012 | Emerson Televison & Video
I want to connect my Panasonic SL-SV570 to my car radio/tape player and have the sound come through the radio speakers. What device do I need to purchase?
You need a cable. Look for the Male RCA/stereo jack dongle/cable so you can connect the stereo jack to the discman and the RCA (male) to the back of your car stereo.
There should be 2 female RCA jacks hanging at the back of the stereo (White and Red).
Jun 05, 2010 | Car Audio & Video
My dc jack is very loss
you need to have it resolderd you need to take it to a repair shop or you will loose power
sorry
Aug 28, 2009 | Computers & Internet
TASCAM US-122 OUTPUT, WHAT SPEAKERS TO USE?
You simply need a cable that converts this rca output to a Jack output.
Here's a link I think is right, though to make sure we would need more info about your model of soundcard:
http://www.kabeltje.com/audio-jack-tulp-c-54.html
I hope this helps,
Yannick
Feb 17, 2009 | Tascam US-122 Sound Card
RCA p60752eb no picture porblem
most likely its a vertical deflection issue, try soldering the vertical otput IC as that may just need to be resolderd, if that doesnt help try replacing the Vertical output.
Sep 16, 2008 | RCA P60828 TV
I have a rca 52 inch tv and when i turn it on it may play a litter while but the picture will go out.
does the audio still continue working when the picture drops out? If so it may be the vertical Ic that is defective or it may just need to be resolderd, often resoldering the IC will fix the problem
May 10, 2008 | Televison & Video
How do I replace a f-type connector on my t.v.
Happens all the time. the way a technician would do it is to remove tuner from unit and if the tuner is not damaged too bad then it can be resolderd back on or a new one put on. Again if the tuner is not damaged which is what happens alot of times when the rf connector is broke off. Let me tell you the most inexpesive way of dealing with this.. feed the signal through another input. eather with a vcr or your cable box.. the rca jacks red white and yellow. then change input on your tv.
Jan 13, 2008 | Televison & Video
Car Audio & Video Logo
139 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
