Question about Husqvarna Garden
Why did my Husqvarna Zero Turn just stop going forward or backwards all of a sudden?
The drive belt is still on.
  • 1 more comment
  • Eugene Rounds May 02, 2015
    Hi Roderick Favor, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is model number? Also is the drive turning when the engine is running?
  • Roderick Favor
    Roderick Favor May 02, 2015
    It's a RZ422F. No the drive belt is not running while the engine is on.
  • Roderick Favor
    Roderick Favor May 04, 2015
    Found the problem. It was the spring that put tension on the drive belt.
  • Husqvarna Master
  • 2,963 Answers
Could be bad clutch, or the transmission shift linkage has come apart or bent.
Posted on May 04, 2015
  • Roderick Favor
stmc97
  • 41 Answers
SOURCE: Was mowing when it just stopped going forward. It
Under the mower below the seat of the rider, at the rear of the tractor, look up and you will find the transmission there. There is a belt that runs on the pulley under there, and this belt can slip off when it gets worn or stretched. Sort of a tough spot to get to but, that is most probably cause.
Let me know,
Chip
Posted on Apr 11, 2010
SOURCE: How do you replace a drive belt on a husqvarna cz4817
i just replaced my belt on a cz 4817. On one side there should be a bar with a spring on it. If you sitting in it it will be on you left side mounted on the deck itself. Push the bar in for about an inch and then up over the lip thats the belt tension spring. you should now be able to remove your old and put the new on. If you need the diagram to show you how to lace the new belt let me know and i will email it to you. good luck
Posted on Jun 16, 2010
  • 112 Answers
SOURCE: I have 2001 Husqvarna lawn tractor model YTH1746 wnt go into gear
those fluid drive transmissions fail on quite a few brands as they all use the same ones....replace the trans...they are expensive but still cheaper than a new mower.
Posted on Jul 21, 2010
  • 6468 Answers
SOURCE: My cub cadet zero turn mower wont turn right or left. It will go straight or reverse but wont turn. I just changed the drive belt, but that's all I've done to it.
take a good look at the linkage
Posted on Apr 08, 2012
  • 6468 Answers
SOURCE: husqvarna zero turn runs great but after about 30 mins the blades stop turning
when this happens you need to see if it you loose power to the clutch to see if the clutch is failing or the circuit feeding it power
Posted on Apr 28, 2012
Zero turn will not move forward reverse or turn
These units use Hydraulic pumps for motivation. If the unit stopped all at one time, I suspect a drive belt came off.
For both pumps to fail at the same time would be very odd. Check the v-belt driving the wheel pumps.
Apr 12, 2015 | Husqvarna Zero Turn Mower RZ4619
My RZ4623 will not move.
If the unit stopped moving at once. I suggest checking the belt. It is very unlikely both Hydro-Gear units would fail at the same time. check under the mower, and check on top of the transmissions, you should see the drive belt running between both transmissions and the engine.
Feb 15, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Was cutting grass and mower just quit pulling
sounds like the drive belt broke you need a new belt
Jan 29, 2013 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
My 42" toro zero turn
the drive belt pulley probably needs replacing or the belt popped off the pully
Apr 03, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
Garden Logo
248 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
